Most TRX's std only develop 70-72Hp and with a little tuning you'll find 76-78 as an average on a std TRX and free flowing cans.
FCR's and a tuned exhaust will give you that extra 10-12 HP and get you in the 86-90Hp region depending on the flow characteristics of the exhaust.
Next ask yourself what YOU want out of your TRX motor and how you want to tailor it to meet your expectations.
Now once you've set your boundaries , research on what will compliment each other to help you achieve your goal.
I'll use my motor rebuild as an example,
Akra exhaust.. Tuned more so for midrange power and slight increase in top end,
The kent cams compliment this to some respect as due to the nature of the reground profile and this boosts the lower midrange characteristics due to the physical restrictions of the regrind.
Everything has boundaries so with the Kent cams by robbing Peter to pay Paul to get the extra 0.4mm lift, material is taken from the base circle on the cam lobe.
What this does then is dictates the nature of the ramp angles which effects the amount of lift of the valve over the whole 300 degrees of duration of actual lift from fully closed -open-fully closed.
Have a look at the flow results on my rebuild thread and you will see close to potential flow within the first half of the lift. but tapers off in the second half due to the duration.
Why, because duration to lift ratio though that early lift period relative to the std cam profile allows just a little more flow due to the ramp on the lobe and how this has been physically achieved by the boundaries placed upon it due to the fact it's been reground from a cam set to work on a different parameter.
The difference with the V2 cam is they have had the research and development and have been designed to meet the parameters worked out from trail and error and testing not only on the racetrack but to perform on the street too.
The only limitation placed upon them is where they would like to see the performance gains in flow(relative to lift/duration) and not like with a Kent regrind which is limited by the physical characteristics to start.
One reason the kent cams are listed as a YAM-9 TDM850 is because they really compliment the characteristics of what you would expect from a sports tourer.
The V2 starts off as a billet blank and the world is their oyster, something the Kent regrind doesn't have. Choice....
This allows the V2 cams to hold the duration of the lift at any specific height to get the best spread of power across a preferred rev range for a sports performance motor like a TRX. (so your gaining in the mid/high rev range)
Perfect example of this is....
This is one reason why you find the lobe centre angles is 1 degree different than the std TRX and Kent option because this would allow just a slightly shelved peak and just that little more duration while the valve is fully open.
The V2 has been developed to optimise ramp angles and lift duration throughout the whole 8.4mm of lift something the Kent cams can't achieve because of the base circle and physical limitation placed upon it.
Cam timing can easily alter the the performance of your motor so 1 degree may not sound like much but there is a method to all this madness and it's specification has a reason.
Another good reason to take a little time to dial in your cams to get the full potentual from your investment.
Don't get me wrong, the Kent cams still have their place.
Remember the boundaries and parameters it has to work with to get the best performance from the modified lobes, hence the nature of the performance they offer..
Don't just look at a final figure on a stated dyno result.
That means $%ck all apart from being a good penis extension.
Look at the dyno result over the whole rev range is what you need and hopefully Andrew may share that soon with us to give you more of a view of the gains over the the complete rev range.
How lucky are we if this all goes ahead, as Andrew is doing this as a love job so guys just take a little time to think (but not to long
![Laughing :lol:](./images/smilies/icon_lol.gif)
) before putting up your hand out of respect for the effort he is willing to do for the benefit of those here on the forum.
A little though on what you want from your motor and how to formulate things to compliment each other..
![Cool 8)](./images/smilies/icon_cool.gif)
