fuel pump
KJP11
fuel pump
Post by KJP11 » Mon Apr 27, 2015 10:46 am
Had my fuel pump slowly die over a period of a 1000km or so. At first drop off of power was hardly noticeable but slowly got worse especially on long straight runs with no throttle movement. While trying to find problem checked pump which seemed to be operating ok so went on to other possible causes only to eventually come back to the pump. Replaced it, end of problem. Got me thinking tho' about the vacuum side of the fuel system. I can understand the pump running on vacuum but don't know what the vacuum tube to the fuel tank does. Any ideas?
Re: fuel pump
Post by dicky » Mon Apr 27, 2015 11:21 am
There is a rubber diaphragm inside the fuel tap that stops the flow if there is no vacuum.
KJP11
Re: fuel pump
Post by KJP11 » Sat May 02, 2015 6:40 am
Cheers for that.
