Replacement fuel caps
- wreckage
Has anybody had any experience with Chinese caps http://www.ebay.com.au/sch/i.html?_from ... p&_sacat=0 ?
Mine's looking a bit grungy and I'm wondering if I should pay top dollar for a genuine, shiny new one or a clone. Advice appreciated.
Cheers.
Cheers.
- Con Rod
Re: Replacement fuel caps
I got one, they are an exact replica of the stock cap. Very good. I recommend them.
http://www.ebay.com.au/itm/Motorcycle-F ... 2ecdd08107
You can swap the lock from your existing cap onto the new one so you still only need 1 key. Just be careful as there are a couple of springs and a small ball bearing that can be easily lost if you are not.
						- wreckage
Thanks, Con Rod.
I am now brimming with confidence and shall order one.
Cheers.
Cheers.
- brockzila
I'm i the market for one also so that is a good info shareingg experence right there.
									Is it Brock friendly???
						- PrfctChaos
Thanks dude, I was also not too keen on having extra keys. Good to know you can swap the lock.
				mrdesmo
I bought one a few years ago, looks the part but never quite closed properly. Had to push hard on it to get it to close.
Got one of these now, and no keys at all!
http://www.ebay.com.au/itm/181384471629 ... 079wt_1100
Havent bolted it on, just sitting there and looks shit hot. Bike in pieces at mo getting a chop and change so not sure how well it'll function in the real world
I had to drill the breather hole a little larger on mine because when bolted up it would seal and about 100km into a full tank . It began to spit n fart till I unscrewed the cap and all good to get me home..
				mrdesmo
Was that in the keyless billet or standard cap Cobba?cobbadiggabuddyblooo wrote:I had to drill the breather hole a little larger on mine because when bolted up it would seal and about 100km into a full tank . It began to spit n fart till I unscrewed the cap and all good to get me home..
On the keyless billet.
I have an idea Alex may have suffered the same fate at some time with his Trx too. But I got it to function properly after a little stress and modification.
Bit like buying a maccas burger and finding the meat paddy still uncooked.
