Fuel capacity / Economy
Balderz337
Post by Balderz337 » Wed May 15, 2013 8:42 am
Just done a trip of a few hundred miles on the TRX, mostly motorway miles cruising at a steady 85 - 90mph. My question is, what is the tank capacity? and what mileage can I expect to get out of the TRX before I have to fiddle my way to the reserve switch? I bottled it at 130 miles indicated (too long riding a Firestorm) and filled back up with 12.54 Litres, and that was brimmed.
There's economical, and then there's bloody economical. I had a Blackbird before this and it was modified, I was returning only about 160 - 170 miles from a tank full on that and its tank was the size of a small African nation. Does this TRX fuel return sound feasible to you experienced guys?
Balders
Re: Fuel capacity / Economy
Post by Mincehead » Wed May 15, 2013 9:15 am
Yep, a well fettled TRX will comfortably see 50 UK miles to a golden gallon of wallet emptier. :wink:
Post by alextrx850 » Wed May 15, 2013 9:26 am
Actual kilometres to reserve I've forgotten, but we were talking about this topic a year ago I think...I do know that from non sloshing (highway) riding..and when the motor first starves....reserve will take you at least 40 Kay's.
skull-candy18
Post by skull-candy18 » Wed May 15, 2013 10:01 am
I got around 55mpg the other day, mostly was a 70mph straight line so best case situation but even when I rev it a lot its still pretty economical. Due to having a lot of torque you don't need to thrash it to make progress.
Post by cobbadiggabuddyblooo » Wed May 15, 2013 10:09 am
18 litre tank with 15L & 3 litres of reserve .. 250 to 300 km before reserve is common so 160/170 miles sound average..
Post by Mincehead » Wed May 15, 2013 11:03 am
Yep that`ll be about right for a stocker with no emulsion tube and needle wear cobba. =D>
Post by fung » Wed May 15, 2013 11:25 am
230 to reserve for miss blackie and the carbs were kitted before I bought it, and has 17/39 gears.
I get better fuel usage with my red Rex that has factorypro TI needles, emulsion tubes, a K&N filter, 2into1 and 16/39 gears.
go figure :)
Post by Mincehead » Wed May 15, 2013 11:31 am
I reckon the stock gearing is actually too high for the lower gears, the motor `hunts` some while in town so not really running as efficient as your dropped 1 tooth bike. :wink:
Post by handsomejackuk » Wed May 15, 2013 12:26 pm
55mpg regularly..... have seen 60 mpg on a run....
M.V.
Post by M.V. » Thu May 16, 2013 7:02 am
Miles? Aren't you chaps up with the proper scientific units yet? 8)
As little as 190km til reserve & as much as 320km to reserve on a midnight to dawn mystery ride.
Usually hit reserve at 220km running around town.
Balderz337
Post by Balderz337 » Thu May 16, 2013 7:45 am
Thanks for all the replies chaps. I think I could have safely pushed her to 140 maybe 145 without having to reach for the reserve. Which, is pretty bloody good. Considering it only costs me around £22 to fill up.
Post by cobbadiggabuddyblooo » Thu May 16, 2013 8:28 am
With the figures you have supplied I think you would got your 250km 145miles before reserve.. Most rides I'll get 270kms even with the FCR'S before reserve and the 250 mark with a bit more traffic..
Post by alextrx850 » Thu May 16, 2013 10:18 am
cobbadiggabuddyblooo wrote:With the figures you have supplied I think you would got your 250km 145miles before reserve.. Most rides I'll get 270kms even with the FCR'S before reserve and the 250 mark with a bit more traffic..
Youre pretty close on the money Cobb.
Post by Con Rod » Tue Oct 21, 2014 6:18 am
A thread revival.
I am consistently getting about 70mpg or 3.9ltr/100km
Fuel range is comfortably over 400km / 250miles
Best tank was 3.7ltr per 100km, or 76mpg which would be a theoretical range of 486km / 300miles
Stock carbs with a 137.5 main jet, middle clip and 2.1/4 turns out. K&N air filter and after-market cans
Regular inspection of the plugs, measurement of the a/f ratio and a camera down the plugs holes shows no evidence of over lean running and no flats spots except for a little stumble at about 2000rpm on the transition from the pilot jet to the needle
Just shy of 90,000km (55,000miles)
but did the valves and rings recently
Post by Killerwhale » Tue Oct 21, 2014 11:39 am
I´m getting 190-220 km to reserve :)
But i´m thrashing it, always.
Con Rod wrote:A thread revival.
