Slow and steady wins the race as they say... Rod has returned from his week away so I put in a few hrs over the last couple of days.
Electrics
I tried another 4 way ignition, not just 1 power in and 3 out like first time.
This 4 wire has 1 power in and 1 power out and the other two break another circuit from wire 3 and 4 when turned on..
I had power to everything but only 1 single spark from 1 plug and only that 1,then nothing..
So 3rd time lucky, 1 power in 1 power out and the other 2 wires complete the circuit when key is turned on..
Yay..
This completed circuit from wire 3 and 4 joined is the one that initiates allowing a continual signal path from the ignition pick ups to the ECU.
If someone tries to hot wire your bike by just running power from the battery to your ignition wire , this is the safety net yamaha has put Inplace.
So power to all circuits and motor turns over and have continuous spark on both pots when cranking.
So radiator inplace, carbies on and exhaust... BUT
Where I have mounted the dash is fouling the throttle cabling when turning the bars...
So I'll make another mounting bracket and instead of mounting where the old dash used to sit, I'll mount it off the front of the top triple tree.
I fitted a 60* - R6 throttle too instead of the std 78* std TRX throttle for a quick response so we'll see how that goes.
Fitted the new cush drive rubbers and locktite and torque the hub so just about ready to roll.
Clip ons all adjusted and set to give me clearance and comfort and end of another 2 days work.
Fluid day tomorrow filling radiator,changing hoses from M/C to reservior and start the bike with Kev's old motor inplace and then make new mounting brackets for the dash.
So fingers crossed I can be mobile Thursday just before Rod goes on holidays again for 2 weeks...
