YZF 6 pots, which master cylinder
Post by Con Rod » Mon May 26, 2014 1:54 pm
Copied from the tyres thread
johnners987 wrote:....
As it is I've got front brake master cylinder issues at the moment so I've got time to think while I resolve that..... I appreciate it's completely off topic but 6 pot calipers and a 14mm master cylinder doesn't seem a good mix......
I have the same question
I have 6 pot YZF callipers which are pretty good for stopping power, but there is a heck of a draw on the brake lever. I am using the 5/8 master cylinder and was going to try the 14mm one that goes with the blue spots, but sounds like that may not be a runner.
Anyone else running the 6 pot YZF callipers had similar issues or found a solution to the long draw on the 5/8 master?
Re: YZF 6 pots, which master cylinder
Post by Tarwetijger » Mon May 26, 2014 2:51 pm
I had a YZF750R and with the original setup the lever always seemed a little loose, a lot of leverage before actual braking action. In fact, I have never seen any YZF750R with tight brakes.
I think this is because of the six pots, needing a siginificant amount of braking fluid to be displaced.
Things might be better with a bigger diameter master cilinder, instead of smaller. A 18 or 19 mm radial Brembo, for example.
Rich
Post by Rich » Mon May 26, 2014 8:33 pm
I used to use -2 lines with Toki 6 pots, lots better.
M.V.
Post by M.V. » Tue May 27, 2014 3:34 am
Better work out the ratios!
What diameter are the pistons in the caliper? You can work out what your ratio should be from here:
http://www.vintagebrake.com/mastercylinder.htm
Snod Blatter
Post by Snod Blatter » Tue May 27, 2014 10:40 am
M.V. wrote:Better work out the ratios!
This is good but I'd just like to say if you're looking to use a radial m/c go with something larger as the pivot is a bit further away so the lever moves a bit more. Using the 27:1 ratio as suggested by the site lead me to a 11/16 m/c but being radial I have a lot of free play at the lever. Phenomenal when it does bite though!
johnners987
Post by johnners987 » Tue May 27, 2014 10:48 pm
Agreed on this (as far as I've got) although more through trial and error than calculation. Currently using an 11/16 (approx 17mm) radial m/c off a Fireblade but there is indeed a lot of play at the lever. Also the m/c is so bloody bulky that it fouls the engine cut out switchgear and rotates the cut out switch under the throttle cables. Looking to source a (slim!) 19mm (3/4) m/c but best do the calculations first this time eh?
=D>
......the louder you scream, the faster we go .......
baverhae
Post by baverhae » Thu Jun 12, 2014 8:14 am
The diameter of the pots is 27mm and 25mm. I used a Brembo 19mm pump.
Owner of a red TRX with a 900 engine, 39mm Mikuni flatslides, 2-1 large bore stainless steel systeem (projection-components), R6 front and back suspension, FZR 1000 swingarm and wheels ... and with water, oil and fuel only 185kg.
johnners987
Post by johnners987 » Fri Jun 20, 2014 3:04 pm
:roll:
baverhae wrote:The diameter of the pots is 27mm and 25mm. I used a Brembo 19mm pump.
Cheers all. Just back from holiday so I've still got this to sort. From the comments so far I assume that the standard 16mm YZF750R m/c has acceptable 'throw' because it is not radial? Personally I'm not too bothered about going radial and a standard 16mm would be acceptable (but muggins also thought the radial 17mm Fireblade would be ok) :roll:
The 19mm Brembo m/c is undoubtedly not cheap(?) and I've got to get costs under some semblance of control as I've still got damn insurance, MoT and tyres to sort (yes, still got to decide on rubber..........)
Can anyone confirm the standard 16mm is a viable alternative and works/ fits given my earlier issues with the Fireblade m/c? Again, my assumption is that it worked fine on the 750 and the throttle cable routing looks similar to the TRX......... and it's a cheaper alternative to the Brembo.
johnners987
Post by johnners987 » Mon Jul 21, 2014 9:34 pm
Notwithstanding the earlier comments (clearly I wasn't paying attention) I've gone with the 5/8ths master and everything seems fine. Two brake lines and a Pazzo lever and it feels like a nice firm lever action with just the right amount of feel/ movement - seems very similar to my R1. All in all very happy given I've also resolved my binding rear brake too so a good day! Time to get some miles on........
