Painful?dandywarhol wrote:Painful butt plug?
Tarwetijgers Winter Works
- Killerwhale
- dicky
Re: Tarwetijgers Winter Works
To expand on my possibly too cryptic previous reply...
A screw is a fastener that is torqued by the head and mounts into a pre-threaded hole or created its own thread in pre-drilled hole or even creates it own hole and thread (ie self tapper)
Nothing at all to do with how much of the shank is threaded. (good wood screws are not threaded all the way to the head)
A bolt may be torqued by the head but is also torqued by a nut attached to the threaded part of the shank.
Many 'bolts' can be used a screws, ie mounted into a pre-threaded hole.
Some screws can be used a bolts, just put a nut on the end and "hey presto, it's a bolt!"
A coach bolt is a good example of the difference. It can not be torqued by the head and must be used with a nut.
<probably wrong>
<probably wrong>
Sigh......................
andyaber
But can you tell the difference between Stork margerine and Pepsi cola?
- cycloneranger
They make margerine from storks!!andyaber wrote:But can you tell the difference between Stork margerine and Pepsi cola?
Keep calm and topp up the oil
- Rod.s
Now you are getting carpentry and engineering confuseddicky wrote:To expand on my possibly too cryptic previous reply...
<probably wrong>
- Tarwetijger
Changed my mind.Tarwetijger wrote:Paintwork almost done. This is what it will look like.![]()
Rest of the engine is black.
Before
After
Gave it a good clean before fitting the engine back.
Did the Samco hoses come with the clamps ?
Looks good the silver barells and cam cover, ever thought of clean shaving the fake cooling fins?...something different.
- Tarwetijger
Yes but is was a €€ option. The clamps are heavier and bigger than the originals.
The fins on the cilinders are sanded blanc! On the head I thought the color difference would be too little to make sense.
- Tarwetijger
Finally: ready for a test drive!
The engine runs well, the handling was terrible... because the tires were still let off for the trackday of last year (about 1.3 bar was left). Inflated them and everything went well!
But... (yes there is a but), I fitted an oil pressure switch light, the Eisi kit, I had it for a long time. The light started to flicker at tick over while the engine was warming up. Man, this really makes me nervous! The banjo bolts I used, had bigger holes than the original bolts that came out. But this shouldn't make to much of a difference. The switch is on the banjo bolt on the cil.head, so almost on the end of the oil-circuit.It reminded me of the inlet cam that turned heavily (see the beginning of this topic) went I took the engine apart. I will have a look for an oil pressure gauge instead of the switch, so I will know a little more.
Any thoughts on this? What are the experiences from others with the Eisi kit?
(engine not running on this pic).
spondontrx
Hi Tarwe , glad to hear she's running
I think there's a reason for the special banjo bolts in the feed line to the cilinder head , if the holes are bigger there's less pressure in the line . causing to much oil to the head (and your warning light to go on) and less elsewhere.
I don't know if it could cause any damage or not ,but I would change that (or at least one off the bolts)
- Tarwetijger
Thank you for thinking along Theo.
It is easy to try the other bolts of course, so that's what I will do.
Also ordered an oil gauge and 20w50 oil. I'll see what happens.
- Tarwetijger
Thanks.
About running in, I am not so sure. There is a lot of discussion online, I dont want to start here another one. On one hand I want to be very gentle, on the other hand it is almost impossible, to stay under 3000 rpm if you want to go along in normal traffic.
And of course I am just curious how it accelerates
In my opinion, don't treat it too gently or you'll end up with glazed bores and oil consumption. Short bursts of acceleration (but not full load) initially then build up the load to bed the rings in.
