Recently changed my chain and sprockets and went with a 41 tooth on the back. Have yet to take it for a decent spin but so far I am happy with it. Also put new tyres or. Michelin Pilot Power 3. Very happy with these indeed.
Will shortly be giving it a bit of an overhaul and have ordered the following
1 94591-40138-00 CHAIN (82RH2015-138L) - CHAIN (82RH2015-138L) $25.24 $25.24
2 3LD-12111-02-00 VALVE, INTAKE - VALVE, INTAKE $12.06 $24.12
4 3LD-12112-02-00 VALVE, INTAKE 2 - VALVE, INTAKE 2 $12.06 $48.24
10 51Y-12119-00-00 SEAL, VALVE STEM - SEAL, VALVE STEM $3.25 $32.50
1 3LD-11193-01-00 GSKT,HD.CVR1 - GSKT,HD.CVR1 $20.28 $20.28
1 4NX-11181-00-00 GASKET,CYL HEAD 1 - GASKET,CYL HEAD 1 $43.00 $43.00
2 93210-90785-00 O-RING - O-RING $3.73 $7.46
1 3VD-11351-00-00 GASKET, CYLINDER - GASKET, CYLINDER $15.82 $15.82
2 3VD-11610-00-00 PISTON RING SET (STD) - PISTON RING SET (STD) $21.97 $43.94
4 93450-22027-00 CIRCLIP - CIRCLIP $1.70 $6.80
1 90430-14131-00 GASKET - GASKET $1.91 $1.91
2 99009-11400-00 CIRCLIP - CIRCLIP $1.00 $2.00
1 5PS-13329-00-00 GASKET, PUMP COVER - GASKET, PUMP COVER $1.00 $1.00
1 3LD-13339-00-00 GASKET, PUMP COVER - GASKET, PUMP COVER $1.72 $1.72
1 91808-16023-00 PIN, DOWEL - PIN, DOWEL $1.00 $1.00
1 90215-21290-00 WASHER, LOCK - WASHER, LOCK $2.23 $2.23
Went down to the Harbour Bridge last night and a mate took a number of pictures with his u beaut camera. I hope to get some more of just my bike from him but thought I would post these up
