What kind of globes it takes: they look weird & there's no marks on them.
What model FZR it is out of: I need get the two rubber covers for the back.
Any help would be appreciated
Cheers.
M.V. wrote:I now have a Dual Projector FZR headlight, courtesy of XXR55, but I need to know:
Cheers.
It is.Killerwhale wrote:Depends, if it´s the 400rr one with red rings it´s special bulbs...effin expensive!
A while back i found those bulbs on wemoto but can´t find em now.M.V. wrote:It is.Killerwhale wrote:Depends, if it´s the 400rr one with red rings it´s special bulbs...effin expensive!
You may be onto something there, I just compared it to a H4, identical pin width & spacing, just smaller... Mini H4?Skybone wrote:From the pic of the rear of the headlight, they look like H4's to me.
H4's have three pins, where H7's only have two pins (my car uses H7's, both bikes use H4's).
I respectfully disagreefung wrote: I came to the conclusion that the oem headlight with HID is the way to go, and i'll leave the 3tj unit unmolested
Fung
Was just commenting that the bulbs shown in the pic couldn't have been H7's, as the one's shown were 3 prong/terminal units, where H7's are two prong/terminal.fung wrote:soz skybone, but they aint at all like an H4.
Smaller in diameter and a different flange. Check the bulb dimensions.
Also the reflector only works with the projector type bulb as it will not spread or penetrate with a std bulb.
Been there done that.
Fung
