speedo
radman
speedo
Post by radman » Fri Aug 03, 2012 8:37 pm
i wonder if anyone can help me? again please, i have boughta set of m.p.h. clocks to replace my kilometre clocks. the only thing is they show 45000 miles whereas my bike shows 30000 ks, does anyone know how i can wind these clocks back to 20000 miles please? i did hear that if you connect it up to an electric drill and run it in reverse that will wind it back but i dont know any ideas please. i dont want to do anything illegal i just want to show the true mileage of the bike. thanks
dave
Re: speedo
Post by trixynut » Sat Aug 04, 2012 11:24 am
the clocks are pretty much a sealed unit.
I have done the drill thing on other speedos but not on the trx. Dont see why it wont work though.
Just give it a little go and see what happens, but be careful you dont mangle the cable connector on the clocks.
Or swap them over when the current clocks read the same as your new clocks.
Or swap them and then ride everywhere backwards for a while.
Or...
Re: speedo
Post by Con Rod » Sat Aug 04, 2012 11:51 am
trixynut wrote:.....
I have done the drill thing on other speedos but not on the trx. Dont see why it wont work though....
yes, this does work on the TRX, I tried it for the same reason in that I swapped the clocks and wanted to put the correct mileage on the replacement ones, however, the drill only gets the speed up to about 120kmph (75mph), so depending on how many miles you want to add:
75miles = 1 hour
750miles = 10 hours
7,500 miles = 100 hours
75,000 miles = 1,000 hours
and so on
i decided to just ride a lot more and let the clocks roll over by them selves
radman
Re: speedo
Post by radman » Sat Aug 04, 2012 6:03 pm
thanks for your help guys i dont want to mangle my speedo so i thik i will just take your advice and ride backwards everywhere, or i could just fit them as i dont intend selling the bike cheers dave
gereen50
Re: speedo
Post by gereen50 » Sun Aug 05, 2012 9:24 pm
Could you take the clock face off the mph clock and put it in place of the kmph one....
I've spent most of my life behind bars
Re: speedo
Post by cobbadiggabuddyblooo » Tue Aug 07, 2012 1:11 pm
Just ride the damm thing and when you sell it put the old one back in :wink: by then you've prob put in 100,000k's.... 15,000/20,000 km a yr isn't hard down here.
SDN
Re: speedo
Post by SDN » Sat Aug 11, 2012 7:48 am
You can change the clock faces pretty easily - so may be the best option
