Standard:
Rebound: 10 (min 3, hard, max 20, soft)
Fast Comp: 7 (min, 16, soft, max, 1, hard)
Slow comp: 15 (min, 24, soft, max, 1, hard)
So, then I tried this:
R: 9
FC: 9
SC: 13
Even worse. I think I went the wrong way on rebound damping, meant to back it off, but added more
Then I tried this
R: 5
FC: 5
SC: 10
Here, I finally figured out I was going the wrong way.
Now I've got this:
R: 12
FC: 5
SC: 10
Pretty happy with it, took it for a blast out in the country & everything seems to come together at about 160km/h, really nice.
Only thing I don't like is it's very jarring around town, so I want to remove some Slow Comp damping & some some rebound damping (I understand you should as little rebound damping as you can get away with)
Also, my preload is on the second last setting, Racetech calc recomends a 10.3kg/mm shock for the TRX & I think 10.5kg/mm for the R6 with my weight, so I guess 9.8 isn't too far off, I was going to replace the rear spring, but I think it'lll be ok...
So anyway, for the questions:
Do you think I'll get away with the stock spring?
Is my presumption about rebound damping correct?
If I remove some rebound damping, will it affect high speed? ie, will it still be as nice at 160km/h?
If I remove some Slow comp, will my bike squat too much under acceleration?
& will it still wheelie?
Thanks in advance.
