Dash mod
- Tarwetijger
Dash mod
I'm working on a modified dashboard. Does this link work?
https://www.facebook.com/10000312411435 ... 980276219/
Re: Dash mod
Nope.
This content isn't available at the moment
When this happens, it's usually because the owner only shared it with a small group of people or changed who can see it, or it's been deleted.
FB links are usually troublesome
- Tarwetijger
- Tarwetijger
Re: Dash mod
The white panel is for prototyping. I got a sheet of 2mm carbon, roughly the same size. I need some test riding and if everything goes as planned and it all works properly, I will replace the white panel with the carbon.
Re: Dash mod
I reckon if I had all de knipperende lampjes on my bike I'd be too busy watching them instead of the road.
- Tarwetijger
- davamb
Re: Dash mod
How are you determining which gear you're in for the gear display? Sounds like it would be a useful thing for my e-Shift, which only synchs on Neutral.
- Tarwetijger
Re: Dash mod
Just straight from the neutral switch. An original one has only one connection for N, but the switch from a later TDM850 (4TX if I remember correctly) has contacts for every gear. It even works with 6 gears!
Like this one for example
https://www.mgparts.nl/product/yamaha-t ... itch-assy/
- davamb
Re: Dash mod
Thanks maaate! Much appreciated!
Edit: After much searching, it seems these parts are virtually unobtainable new and second-hand ones are silly money. Looking at the part, it appears that it would be possible to modify; drilling contact holes and inserting contact slugs to connect to. As it turns out, someone else has beaten me to the punch:
https://www.tdm-yamaha.heliohost.org/?page=GID
- Tarwetijger
Re: Dash mod
I think €20 for a used one is not too bad but I think it is on the wrong side of the globe for you.davamb wrote: ↑Tue Mar 21, 2023 7:23 pmThanks maaate! Much appreciated!
Good description indeed!
No need to fiddle with diodes yourself, on aliexpress you can find displays with the electronics built-in, you can connect it straight to the neutral switch.
