Dash mod
Dash mod
Post by Tarwetijger » Fri Mar 03, 2023 2:43 pm
I'm working on a modified dashboard. Does this link work?
https://www.facebook.com/10000312411435 ... 980276219/
Re: Dash mod
Post by dicky » Sat Mar 04, 2023 1:56 am
Nope.
This content isn't available at the moment
When this happens, it's usually because the owner only shared it with a small group of people or changed who can see it, or it's been deleted.
FB links are usually troublesome
Re: Dash mod
Post by Tarwetijger » Fri Mar 17, 2023 8:58 am
I cant get the video to work in an other way so I'll stick with some pics.
old
new setup
motogadget pro dash, Innovv K1 dashcam with camera front and rear, gear indicator, voltage and cooling temperature (koso).
Re: Dash mod
Post by Tarwetijger » Fri Mar 17, 2023 8:59 am
The white panel is for prototyping. I got a sheet of 2mm carbon, roughly the same size. I need some test riding and if everything goes as planned and it all works properly, I will replace the white panel with the carbon.
Re: Dash mod
Post by dicky » Fri Mar 17, 2023 9:25 am
I reckon if I had all de knipperende lampjes on my bike I'd be too busy watching them instead of the road.
Re: Dash mod
Post by Tarwetijger » Fri Mar 17, 2023 11:46 am
You have a point probably it is just that I like knipperende lampjes that much! 8)
Re: Dash mod
Post by davamb » Fri Mar 17, 2023 5:56 pm
How are you determining which gear you're in for the gear display? Sounds like it would be a useful thing for my e-Shift, which only synchs on Neutral.
Re: Dash mod
Post by Tarwetijger » Fri Mar 17, 2023 11:03 pm
Just straight from the neutral switch. An original one has only one connection for N, but the switch from a later TDM850 (4TX if I remember correctly) has contacts for every gear. It even works with 6 gears!
Like this one for example
https://www.mgparts.nl/product/yamaha-t ... itch-assy/
Re: Dash mod
Post by davamb » Tue Mar 21, 2023 7:23 pm
Thanks maaate! Much appreciated!
Edit: After much searching, it seems these parts are virtually unobtainable new and second-hand ones are silly money. Looking at the part, it appears that it would be possible to modify; drilling contact holes and inserting contact slugs to connect to. As it turns out, someone else has beaten me to the punch:
https://www.tdm-yamaha.heliohost.org/?page=GID
Re: Dash mod
Post by dicky » Tue Mar 21, 2023 10:26 pm
That's a good find.
Excellent description of how to build it.
Re: Dash mod
Post by Tarwetijger » Wed Mar 22, 2023 10:49 pm
I think €20 for a used one is not too bad but I think it is on the wrong side of the globe for you.
Good description indeed!
No need to fiddle with diodes yourself, on aliexpress you can find displays with the electronics built-in, you can connect it straight to the neutral switch.
