TRX Restoration Project
Re: TRX Restoration Project
Post by cobbadiggabuddyblooo » Mon Dec 16, 2013 1:00 pm
Good idea.. :wink:
Rod had a cunning plan just like that so I've modded a set of Akrapovic headers with two bungs just before the balance pipe to accomidate two wide band O2 sensors that he has, so we can get the air fuel sorted for each pot.
Then the only dyno time is for tweeking the timing with the programmable ignition saving time and ultimately money.
I figured the money saved on dyno time has pretty well much paid for the ignition which is a lot easier just progamming on a P.C. than time pulling carbies a part.
Post by Con Rod » Mon Dec 30, 2013 5:46 am
I am planning on just using one sensor but weld in 2 stainless bungs so I can swap between the 2 pipes.
With the belly pan on mine it looks like I will need to weld the bungs on below the water pump (right side) and sprocket cover (left side) so as I have sufficient clearance for everything.
Probably get the wiring sorted tonight but will need to take the headers off and take them to a muffler place to get the bungs mig welded on
Tip for anyone doing this is to get stainless bungs and plugs. A lot of the bungs are mild steel and indeed a lot of places sell stainless bungs with mild steel plugs :roll:
I got a pair of these
http://www.ebay.com.au/itm/151177890170 ... 1439.l2649
Post by Con Rod » Thu Jan 02, 2014 10:51 am
Almost done installing the o2 sensor on my bike. I have all the wiring done but I need to get a couple of bungs welded onto the header pipes to screw in the sensor itself. Unfortunately all of the local muffler places are closed still so will have to wait.
Anyway here is a picture of the gauge
and this is under the rear seat, where I put the control box etc. The switch on the left allows me to turn the whole thing off if I want to disconnect the sensor, the momentary switch is to calibrate the sensor and the led communicates the status of the sensor
Post by alextrx850 » Thu Jan 02, 2014 11:40 am
Paul, what is the small yellow thing mounted to your clutch bracket, looks like an LED.?
Like the front brake resevoir...too
And your lap top indicates download complete. :lol:
Post by Con Rod » Thu Jan 02, 2014 11:49 am
Well spotted Alex, that's for my home made chain oiler.
Page 10 of this thread
viewtopic.php?f=6&t=7414&start=135
Post by Con Rod » Tue Jun 03, 2014 2:50 pm
Recently changed my chain and sprockets and went with a 41 tooth on the back. Have yet to take it for a decent spin but so far I am happy with it. Also put new tyres or. Michelin Pilot Power 3. Very happy with these indeed.
Will shortly be giving it a bit of an overhaul and have ordered the following
1 94591-40138-00 CHAIN (82RH2015-138L) - CHAIN (82RH2015-138L) $25.24 $25.24
2 3LD-12111-02-00 VALVE, INTAKE - VALVE, INTAKE $12.06 $24.12
4 3LD-12112-02-00 VALVE, INTAKE 2 - VALVE, INTAKE 2 $12.06 $48.24
10 51Y-12119-00-00 SEAL, VALVE STEM - SEAL, VALVE STEM $3.25 $32.50
1 3LD-11193-01-00 GSKT,HD.CVR1 - GSKT,HD.CVR1 $20.28 $20.28
1 4NX-11181-00-00 GASKET,CYL HEAD 1 - GASKET,CYL HEAD 1 $43.00 $43.00
2 93210-90785-00 O-RING - O-RING $3.73 $7.46
1 3VD-11351-00-00 GASKET, CYLINDER - GASKET, CYLINDER $15.82 $15.82
2 3VD-11610-00-00 PISTON RING SET (STD) - PISTON RING SET (STD) $21.97 $43.94
4 93450-22027-00 CIRCLIP - CIRCLIP $1.70 $6.80
1 90430-14131-00 GASKET - GASKET $1.91 $1.91
2 99009-11400-00 CIRCLIP - CIRCLIP $1.00 $2.00
1 5PS-13329-00-00 GASKET, PUMP COVER - GASKET, PUMP COVER $1.00 $1.00
1 3LD-13339-00-00 GASKET, PUMP COVER - GASKET, PUMP COVER $1.72 $1.72
1 91808-16023-00 PIN, DOWEL - PIN, DOWEL $1.00 $1.00
1 90215-21290-00 WASHER, LOCK - WASHER, LOCK $2.23 $2.23
Went down to the Harbour Bridge last night and a mate took a number of pictures with his u beaut camera. I hope to get some more of just my bike from him but thought I would post these up
Post by Con Rod » Wed Jun 11, 2014 5:37 am
some more pictures from Vivid in Sydney last week
Post by Con Rod » Tue Jun 17, 2014 2:58 pm
after taking the engine out of the frame last night, in order to make the work easier I got started on overhauling the engine tonight.
Plan is to hone the cylinders, replace the rings, replace the inlet valves, reseat and replace the valve stem seals for all the valves and replace the cam chain.
Tonight I got the stripping it down,
Head off
Pretty clear that the valve stems seals are letting plenty of oil in to cylinder 2 (top of picture)
the bores actually look pretty good.
hot exhaust valves on cylinder 2
rings looks to be doing a decent job, but will be replaced
Subaru upper engine cleaner got all the baked on oil of the piston from cyl 2
All clean
Post by dandywarhol » Tue Jun 17, 2014 6:26 pm
Does it smoke/smell of oil under load or after overrun Con?
Post by davamb » Wed Jun 18, 2014 12:47 am
Con Rod wrote:the bores actually look pretty good.
Do you think the rings bedded-in properly?
Con Rod wrote:Subaru upper engine cleaner got all the baked on oil of the piston from cyl 2
MrMuscle oven cleaner does a great job too, might be a bit cheaper as well - knowing Suby products!
Post by Con Rod » Wed Jun 18, 2014 12:51 am
It looks a bit glazed to me, but I think the rings bedded in reasonably well. Fortunately I have a mate who works for Subaru :D
Post by dandywarhol » Wed Jun 18, 2014 12:00 pm
That's why I asked the oil burning question. If it burns under load it's the bores/rings - if after the overrun, it's the valve seals. I also think the problem is glazed rings due to too careful running in.
Never really seen worn/hard valve seals on a TRX/TDM engine.
It would also be worth checking the clearance between the piston compression rings and the piston ring lands in case the rings are "floating"
Post by Con Rod » Thu Jun 19, 2014 1:17 am
dandywarhol wrote:That's why I asked the oil burning question. If it burns under load it's the bores/rings - if after the overrun, it's the valve seals. I also think the problem is glazed rings due to too careful running in.
Sorry, I thought I had posted a response to your question yesterday but I must not have hit the submit button,
I am not really sure where it smokes, I think on the overrun and if you hammer it out of a corner, but not sure. I will ask a mate who is usually following me.
The valve seals on cylinder 2 inlets look to be leaking for sure though, from looking at the piston crown and also where i look in the inlet manifolds there is some evidence of oil in there. The always look abit wet.
In any case I will be honing the cylinders and have new rings to go in. Also am replacing all if the valve stem seals and the inlet valves.
As suggested I will do all the inspection measurements
Post by Con Rod » Thu Jun 19, 2014 1:28 am
ok, I asked my mate and he tells me:
It does smell more oily than what a normal “fuelly” smell would be. It never seemed to smoke visibly tho, maybe a little puff after off throttle engine braking back to on throttle (nothing visible under load that I remember).
Post by cobbadiggabuddyblooo » Thu Jun 19, 2014 3:06 am
Hi Paul,
How did the gauze filter look inside the sump and the dry sump :?: :?: . I found a quite a lot of gunk inside the tank on this gauze filter when I pulled my motor down and a long stringy piece of silicone about 3" long on the other down the bottom.
