I have proof!!
Rod.s
I have proof!!
Post by Rod.s » Wed Oct 31, 2012 9:30 am
Some of you may remember i questioned the crap that we all find in our carbs and from where it was coming!!
Some photo's to jog your memory :D
The crap, which i believe is rubber from the rear tyre, flung onto the engine and then sucked into the carbs
The see through standard Yamaha filter
The issues as I see them....
Well my solution was to fit a crank case breather/filter, like thus, you can see the standard Yamaha sucker on the right still fitted :lol:
Well today was carb day at the Smith house, and i was itching to have a look at the carbs innards 8-[
After 500ishK's the difference is obvious, carb on the left "Yamaha" breather = crap....carb on the right an aftermarket crankcase breather = No crap :D
Yep i have now fitted the other aftermarket breather to the recalcitrant carb :D
Re: I have proof!!
Post by alextrx850 » Wed Oct 31, 2012 11:33 am
Well, there,s food for thought...without doubt the paper style filter has done its job well..ineresting to what the rubber type of crud it is and where its coming from..tyre..yeah....what about old rubber tubeing delaminating...something thereabouts...at least its not coming from the slides and a filter fixes it..well done =D>
Rod.s
Re: I have proof!!
Post by Rod.s » Wed Oct 31, 2012 11:52 am
I still think it's the tyre :thumbright: as the rubber I tear up has got to go somewhere :D Much like the reason for the MX goggles i wear, they protect me from the dirt/mud/crap the tyre throws forward that i eventually ride through. I surmise that the rubber thrown forward has to go somewhere and as the carbs are sucking air......It would be interesting to see the innards of someones carbs from a bike that has a rear huger fitted (after cleaning the carbs first :roll:)
Re: I have proof!!
Post by Mincehead » Wed Oct 31, 2012 12:36 pm
Don`t do rear `hugers` myself, I like petite butts on my wimmin. (read your post again) :wink: :lol:
Re: I have proof!!
Post by Con Rod » Wed Oct 31, 2012 1:44 pm
interesting, and presumably all sorts of coarse dust could work its way in there too, which could there conceivably work its way into the needle jets and cause the needles and jets to wear out prematurely.
Re: I have proof!!
Post by cobbadiggabuddyblooo » Wed Oct 31, 2012 1:50 pm
well done Rod...next round of coffee is on me :lol:
Rod.s
Re: I have proof!!
Post by Rod.s » Wed Oct 31, 2012 11:29 pm
Mincehead wrote:Don`t do rear `hugers` myself, I like petite butts on my wimmin. (read your post again) :wink: :lol:
Oh "g" here is the extra you were asking for :D
Rod.s
Re: I have proof!!
Post by Rod.s » Wed Oct 31, 2012 11:48 pm
cobbadiggabuddyblooo wrote:well done Rod...next round of coffee is on me :lol:
Do you have my special coffee :coffee:
M.V.
Re: I have proof!!
Post by M.V. » Thu Nov 01, 2012 12:54 am
Interesting find, good detective work!
Better pull mine apart & see how they're going...
Re: I have proof!!
Post by cobbadiggabuddyblooo » Thu Nov 01, 2012 3:30 am
yes mate...Janets neice and partner who's a pilot in New Guinea right :lol: but the other two...well I got 5 other types now to try :lol:
ritza
Re: I have proof!!
Post by ritza » Thu Nov 08, 2012 2:26 am
well, last week i pulled my carbs apart and found them chokka with the black stuff :shock: and put it down to the wear from the slides. it felt the same as plastic more so than rubber...but you throw up an interesting alternative....mike
Rod.s
Re: I have proof!!
Post by Rod.s » Thu Nov 08, 2012 3:11 am
ritza wrote:well, last week i pulled my carbs apart and found them chokka with the black stuff :shock: and put it down to the wear from the slides. it felt the same as plastic more so than rubber...but you throw up an interesting alternative....mike
If your slides wore at that rate then you would have to replace them at the same time as your tyres :shock:
Re: I have proof!!
Post by cobbadiggabuddyblooo » Thu Nov 08, 2012 10:46 am
Maybe he slides around on his tyres.. Now there's a thought.. Doin a bit of drifting on 2 wheels would throw up plenty of charf :wink:
