Throttle cables?
osbxrt
Throttle cables?
Post by osbxrt » Tue Mar 01, 2016 5:36 pm
I need to raise the handle bars on my TRX and I may need longer throttle cables.Can anyone tell me if TDM850 ones will fit, Yamaha list 2 part numbers,one before the 1999 MY and one after.Just which one fits is the problem-any ideas?
Re: Throttle cables?
Post by dandywarhol » Tue Mar 01, 2016 8:11 pm
Can't see why they wouldn't fit - the pre '99 carbs are identical to the TRX. The post '99 had different carbs but I can't see the reason why the cables wouldn't be suitable :?
osbxrt
Post by osbxrt » Tue Mar 01, 2016 11:25 pm
Thanks for that Dandy,time to start collecting bits then.
Post by Con Rod » Wed Mar 02, 2016 12:33 am
you might find someone on here has a set of YZF750 ones which might work, they are pretty much identical to the TRX ones but a little bit longer
Post by cobbadiggabuddyblooo » Wed Mar 02, 2016 2:48 am
Post 99 they changed the carbies on the Tdm 850.
Don't know if the throttle action set up is different on the carby though.
They are still a Mikuni 38mm CV down draught carb but not exactly the same as the Trx carby.
Post by dandywarhol » Wed Mar 02, 2016 8:42 am
Did I hear an echo to my reply?
8)
Post by cobbadiggabuddyblooo » Wed Mar 02, 2016 10:43 am
YES Yes yes. :lol:
You never stop learning
