Shorter sidestand
Shorter sidestand
Does anyone know of any sidestand to fit the TRX that are shorter than the original?
After my front end rework the bike is now lower and it stands up almost vertical when parked on the sidestand.
I'd rather not cut into my original stand, hoping to find another that bolts straight in but is a touch (1/2" should do ) shorter.
- davamb
Re: Shorter sidestand
Be interested to see what you find Dicky, same problem here.
Check out the R1 side stand , I recall they may be the cure your after.
Aaaah Ok, that's obviously what they use with shorter dog bones with the arse end raised.
- fung
I'll have to check..but iirc early R6 ie 99/00 may have a shorter stand compatible.
grumpy1
Anybody ever figure out the answer to this problem? R6 sidestand is longer than TRX as well
Basically it goes like this: Buy another TRX side-stand and `doctor` it, SIMPLES.
