front tyre
front tyre
got a michelin pilot power 120x60x17 on front 34psi appears to be wearing a lot more on the right hand side. any reason for this. cheers brush.
- Wombat
- Forum Marsupial
Re: front tyre
Straight roads and road camber. As much as we would like to think otherwise most of our travel is in a straight line.brush wrote:got a michelin pilot power 120x60x17 on front 34psi appears to be wearing a lot more on the right hand side. any reason for this. cheers brush.
For a front tyre its heaviest load and peak wear is under brakes and if you are doing it the way "the book" recommends then your hard braking happens before you tip into a corner. At close to max braking power most of the bikes weight is on the front tyre and the contact patch flattens out, so most of the wear happens in two bands about halfway between the tyre centreline and the outside edges of the tread. This is why fronts wear pointy, unlike rears that wear flat.
In most places in the world roads have a raised crown to help water drain off, the exception is places that need snowplows for the winter (Sweden for one) as the blade needs a flat surface to work.
So as you ride along the road is at a slight inclination to the front tyre. Apply the brake and not only do you distort the contact patch but it distorts more on the right hand side, and wears more on the right as well.
So its a normal wear pattern, and even though its usual for a front to have plenty of tread left when a rear is worn out they are usually worn enough to effect the steering at that stage so I tend to replace both.
DFH
