radiator
- billy budge
radiator
hello all,
im after a mahoosive favour if i may be so bold, and that is the measurements of the standard radiator.
im just after the real basic 3 i think, width/height/thickness please.
Even more ideal would be if someone would be lovely enough to A) have one spare lying around and B) be able to lend it to me for a while and i would pay for postage there and back.
I dont have the bike at the mo as its having alot of new trick electronic things, amongst a whole heap more of trick bits, installed so cant get measurements myself. Im after getting a bespoke and very nice ally one made up so borrowing one would be tops so he could copy all the outlets on it.
many thanks in advance.
Re: radiator
ca 32 * 310 * 190, that's the measures of the radiator element itself. The overall width is ca 390 mms.
Re: radiator
Funny to see that other people have your same ideas too.
I'm preparing a naked bike and don't like the radiator being larger than the frame.
You can get the same cooling area by increasing the height (although this may not just be the same: more water passes faster through a shorter cooling path. Hence do we end having yet warmer water?).
I've been looking quite a while on ebay for radiators with 'ideal' sizes: Search of needle in the hay...lots of radiators...nobody thinks measures could matter at all. Then I noticed that radiators vary even more in thikness! Small engines have thin radiators. Is this just because a big engine needs recirculating more water? To thin a 'diameter' would cause much drag? Too little water get's cooled in time, so the lot remains hot?
And how does the thickness then relate to heighth? The whole is completely misterious to me. Got really confused . So I decided that once my project reaches that point I would give it a try and watch temperature...
But your intentions now open a fully new perspective to me! What are you exactly after? Maybe I could need such an alloy made one too...
Let me know
Let me know
(My profile is still as stock as my Trixie is, this might change)
- billy budge
Re: radiator
Come on all you trx parts hoarders, i know one of you collectors must have a spare rad lying around for little old me to borrow....PLEEEEAAASE!!!!!
The guy reckons madivi, who makes them for 2 strokes mainly so knows how hot or cold things should run, that once he knows what size i want to go down to can usually make it up in thickness. He makes dual core rad's that are twice as effective, funnily enough, and these keep highly strung race tuned 2 strokes cool on even the hottest of days. Reckons some rads he makes are 40 odd mm thick.
Re: radiator
Until about 2 weeks ago i had one gathering dust, so I sold it!
The TRX does not run hot so with decent coolant (and a fan) you should be able to come down in size a fair bit
Re: radiator
If I'd tell you my wish size and you could have it calculated and seriously estimated at a reasonable price as well as getting it for me, I could borrow you mine.billy budge wrote:...that once he knows what size i want to go down to can usually make it up in thickness...
Ok, lots of conditions - but you see I'm not living next door...
- billy budge
Re: radiator
Thats just another poke in the eye from sod's law eh Pete!!!
Nevermind im sure somebody has one, ta very much for the tip mate. Its all good info i can pass on, he makes them identical for outlets, mounting positions, fan fixing points etc so hopefully it will be quite a compact little beauty if i can drop a fair bit in size.
What coolant do you recommend Pete and where can i get this please buddy, ive only used bog standard stuff until now.
I will see if i can find one over here to borrow first madivi but if i cant get one then i will have to remove mine, dont really want to as it means i cant use the bike for nother few weeks. Let me know sizes though and i can put in a double order and maybe negotiate a deal with him!!
Re: radiator
As for coolant, I have tried Watervetter. It's supposed to cool better, and it's not slippery should You get a leak. No anti-freeze though. Not that I noticed much difference in engine temps though. It's at least said to reduce "hotspots", i.e. local extra hot places where the coolant can start to boil.
No chance You could get a radiator that would be more efficient than the standard. I am, as opposed to what Phuk said, having a bit of an over-heating problem. (But when the engine was standard, it was no problems at all...) If Your guy could make something that's more efficient, then I'd be interested as well, depending on costs. Otherwise I have been trying to source a R6 radiator, 2003 model should slot in nicely, and is curved and higher which means more area and better cooling.
Re: radiator
Can't remember what it's called but it's yellow
comes in 1litre bottles for about £6 - better than water and anti freeze / coolant home brew
- billy budge
Re: radiator
Cheers youngy (my ebay mentor!!!!)
Well Pete think i found something close to what you recommended, ive got a choice of rockoil or putoline to choose from for around 5 quid a litre.
Had a laugh at a product in demon tweeks that claims its twice as wet as water, i know what theyre aiming at but the wordings all wrong...wetter water eh!!!
Also looking at the samco hose kit for increased cooling effiency but also thinking if the rad is gonna be narrower than stock then the samco hoses will be useless, can you buy pressure tested silicon tubing in those sizes and more importantly where from??
Ta.
Ta.
- slow codger
Re: radiator
Billy, put a search engine in for silicon tubing, or try these
http://www.silex.co.uk/silicone_tubing. ... 1AodTXU_5Q
- billy budge
Re: radiator
Thankyou my good man, dont do computers much so you have to bear with me on the tecnicalities pal!!
