Cafe racer rebuild and restoration.
knumbnutz
Re: Cafe racer rebuild and restoration.
Post by knumbnutz » Wed Oct 22, 2014 12:08 pm
Thanks Steve. Pm..
Pictures showed that we lived
BennyTRX
Post by BennyTRX » Sat Nov 01, 2014 8:55 am
Hows the progress on this.
Mine is 90% done. Just needs a tidy up underneath. Ive gone for a modern cafe look.
knumbnutz
Post by knumbnutz » Mon Nov 03, 2014 12:58 am
Progress at the moment is just getting all the parts together.
So far -
Disassembly of bike
Single sided swingarm and 8spoke wheel
FCR41mm Flat slides
rubbers for carbs
R1 forks, 6pot calipers
YZF750 triple clamps
Clipons
Still looking for/deciding on
rear shock
rear tail unit - probably going to replace it with 1098 ducati subframe or maybe just small seat /duck tail style custom fibreglass unit
headlight
Post by alextrx850 » Mon Nov 03, 2014 1:27 am
Any progress to the vfr swing Niel ?
Took me six months to find that rc36 wheel from the Netherlands.... if I see another, will let you know.
knumbnutz
Post by knumbnutz » Mon Nov 03, 2014 11:50 am
Hi Alex,
I found a 8spoke mag off a 91 model 5.5inch with a 180/55 on it, in good nick too, for $365 so I have that now. It's in a light gold colour.
Just working on a shock and tail section now. If the motor is ok, then all I'll have to get is speedo headlight and a couple of small bits. Fingers crossed
Cheers Neil
knumbnutz
Post by knumbnutz » Tue Nov 04, 2014 11:53 am
Hi guys, so I went to the Shed today and stripped the old wheels to lighten them and send in the post.
Then I finally mustered up the courage to drain the sump and check out the oil. Phew! Looks good, oldish and no sign of bits or half a bottom end. That is really pleasing.
So I got back into it and stripped off the pipes and some bits off the bike.
I'll post some pictures later.
Regards Neil
BennyTRX
Post by BennyTRX » Fri Nov 07, 2014 8:04 am
Can I see a pic of the wheels?
knumbnutz
Post by knumbnutz » Mon Nov 10, 2014 1:05 am
Which Wheels ?
original marchesini or 5spoke/8spoke single sided ones ?
knumbnutz
Post by knumbnutz » Tue Nov 18, 2014 6:31 am
Forgetting the colour scheme for the moment as it will be black and gold (no green), i have come up with a render which hopefully will be close to the final bike.
Almost all the parts are on the way, including a 1098 tail section and seat as per image - not sure whether it will fit, but when it gets here i'll be able to measure and find out.
I have a custom Hyperpro shock being made. I have also checked the swingarm and will need to machine it down about 20mm in width, so that will be joyful ,not.
Post by Con Rod » Tue Nov 18, 2014 6:56 am
very nice, just add one of these belly pans in a colour to match the tank and it will be awesome
http://www.the-simple.info/
available from here
http://www.j-mart.biz/j-parts/index.php ... bng14537k0
more pictures in the November issue of Practical Sportbikes
knumbnutz
Post by knumbnutz » Tue Nov 18, 2014 7:48 am
thanks Paul,
I will probably keep it naked and I am not sure a belly pan will fit as I may still do the very curved version headers like on the domiracer, we'll see.
It certainly looks the part on a faired bike !
Post by Con Rod » Tue Nov 18, 2014 7:57 am
Not really clear from that picture but it sort of boxes in the engine as a mirror of the tank.
I will see if I have a picture without the fairing to better demonstrate
knumbnutz
Post by knumbnutz » Tue Nov 18, 2014 12:24 pm
Ok cool.
knumbnutz
Post by knumbnutz » Thu Nov 27, 2014 4:59 am
I wont say progress is swift, but things are at least happening.
I have removed the swingarm, shock and pipes after this pic was taken.
I have a whole bunch of stuff here ready to go on the bike, including a rear subframe from a 1098 ducati (hopefully i can make it fit) with a seat and carbon fiber rear tail unit.
I bought a Milling machine today so I am going to make my triple clamp once my house is built and I have somewhere to use it.....
A couple of things that I want to ask, has anyone put on a curved R6 radiator ?
They look very similar in size and the pipes go in the same places and new they are only $100AUD.
regards Neil
Post by alextrx850 » Thu Nov 27, 2014 9:00 am
Aha...where is the vfr rc36 rear wheel.....?
