by dandywarhol » Sat Apr 04, 2015 10:25 pm
Can someone remind me if there's an "O" ring to seal the emulsion tube to the body? It's about 15 years since I changed tubes on a TDM and my memory is mush.
My TRX is drawing fuel past the left carb emulsion tube when idling (with the airbox off obviously) and if I cup my hand over the same intake the engine revs rise
![Shocked :shock:](./images/smilies/icon_eek.gif)
The fuel can be seen spraying down the carb between the tube and the body.
Stu99
by Stu99 » Sun Apr 05, 2015 12:15 am
There is an o-ring that seats in the jet block.
Stu99
by Stu99 » Sun Apr 05, 2015 12:24 am
Quick pic.
by dandywarhol » Sun Apr 05, 2015 1:22 am
Thanks Stu - it's coming back to me now. I guess the old ring has perished with ethanol/age. I've got an "O" ring kit in the garage - I'll try a repair tomorrow. Thanks again.
Are those Factory Pro tubes?
Stu99
by Stu99 » Sun Apr 05, 2015 1:48 am
Yep, thats my spare set with a factory pro kit installed, the ones on my bike have a tovami kit with factorry pro tubes.
by dandywarhol » Sun Apr 05, 2015 5:11 pm
Job done - found an O ring in my box of bits and no more leaking. Idling much better. Might have to do the emulsion tubes sometime - at 11,000 miles there's a little bit of ovalling. The previous owner was a canny rider and didn't rev much - the slides rattle back and forth if lugging the engine and that wears the tubes
I was being an erse when the idle speed rose when I partially covered the mouth - I'd forgotten about the vacuum pipe for the fuel tap
![Embarassed :oops:](./images/smilies/icon_redface.gif)
