blue spots inf needed
- Racer-unk
What is the working contact height of the blue or gold spot R1 brake pads on the discs? Please!
Re: blue spots inf needed
In reguards to fitting a heavier rear Spring to the std shock.
Free Spring length is 220mm and compressed length is 202mm so at least you can source a heavier rear Spring.
- Racer-unk
me thinks you got lost in the maze Cobba............
- OzzieDave
Can you describe how you want this measured.
