Gear box rumble..???
Hi,
my first post here, i just bought a TRX 850, In austraila, 1999 model, very well cared for 110,000k
motor runs like a charm, but when riding, (not sure if its in my head) i seem to hear a "rumble"
has anyone had any issues or know of any issues with bearing on these gear boxs...???
In nuetral, with a warm engine no noise..... seems to be thrid or fourth gear....???
I have only done 330k on the bike, will drop the oil and have a look.... any put or links would be great.
Thanks Looseplug.
Thanks Looseplug.
- fung
Re: Gear box rumble..???
Location helps.
Might have someone close by to help
- Gordo
Is the chain in good repair & have you checked the condition of the front sprocket? Check if the chain rollers have worn too far into the sprocket teeth. If either are very worn/poorly lubricated, seized & stretched links etc. It can create a rumbling sensation & noise on most bikes.
If you collect the oil in something clean and it & the filter are ok, just pour it back in when you're done.
Good luck!
Gordo-
Good luck!
Gordo-
Third and a little in fourth will give a whine Looseplug,my original 96 motor had it bad,..just in third, but I think all Rex motors have the third gear whine..if you've just had a four cylinder machine, you will find a lot more character in the TRX.
Enclose your location, this is a must as there will be someone about to come and have a listen.
Otherwise it MIGHT be a loose plug....Looseplug.
Aha..Looseplug...gumtree says you are in Nambour area.
- Stu99
The guys have made good points.
If however the rumble is emanating from the two shiny pipes pointing rearward of the bike, then all is good.
Best way to cure any strange noises from the motor is to put on some loud cans....
Otherwise, first check the easy things not involving getting into the motor, like chain, sprockets, wheel alignment, wheelnuts tight, bearings etc.
It could be the noise is at a certain speed which just tends to coincide with when you're in 3rd/4th gear area.
- emway
Hmm, the whine noise in third gear is louder than mine BOS exhaust without the db-killers.
Earplugs fixed my whine over 50,000km ago. So when Janet goes" you and that bloody bike" earplugs in, the whining stops"
But in the back of my mind I have that feeling one day things will crack and I'll have to deal with metal banging into my head from the fry pan..
- fung
Hope she doesn't read your forum texts bryzee
Thanks for the input...
My location is Nambour, QLD. (blue bike)
Chain n Sprockets, all new, as are the tyre pressures correct....
I do have a decent set of cans on there... ear plugs next...lol
Bike rides and stops as it should, the only issue... is this rumble... but doesnt effect the speed/torque when riding.
Bike has done a few Ks 117,000k.... and only three owners, maybe its all in my head..??
yes this is correct.... blue trx 850...if u see it around.alextrx850 wrote:Aha..Looseplug...gumtree says you are in Nambour area.
