Spark Plug Change
Posted: Tue May 03, 2016 7:23 am
This post is more for advice then to pass on a pearl of wisdom...
Finally got around to doing a service on my trx, its just shy of 40,000 miles. It gets an oil and filter change every 4,000 any way but she needed a new chain and sprockets, i fitted a scottoiler, clutch cable, new cush drives and spark plugs. What an absolute holiest of holy of a job changing the spark plugs is! Has anyone picked up any crafty hints, or is it just me that spent several hours stripping most of the bike apart to be able to get enough throw on the ratchet to get a single click.
I had the radiator off its mounts and had to unfasten the right hand coil to get enough slack on the HT lead, at one point I did consider dropping the engine out of the frame. It seemed like the frame was deliberately designed so that something was always in the way.
Eventually I swore enough that the old plugs came out, though they were only just finger tight and a new set of Iridium plugs went in. Took it for a spin and it seems to pick up much sharper, previously there was a lag at very low speed/minimal throttle opening.
