seeing as though in the main all the work is done on my TRX900, I have decided to progress my dad in laws TRX project for him. he is currently getting some house work done and his bike was being stored in my garage, so it would be rude not to really
so a bit history on it:
I found it on gumtree, through a link on here actually. I called the guy up, and the bike turns out to be a Bemsee thunderbikes championship winning bike, and comes with 878 big bore, kent cams, and 41mm FCRs, 2 into 1 'custom' exhaust system, and a shed load of spares including fairings, belly pan, wheels, and what looks like an entire spare engine in parts.
When I had a good look at it it turns out hes done a lot of work stripping of parts that are not necessary, including all none necessary wiring like indicators etc. I also noticed a lack of a rectifier, so I suspect it was running a total loss system. I am hoping he wasnt too thorough and pulled out the alternator from the engine. If thats the case then we have spares to go in
You will notice the crash bungs have been nicely 'shaped', and judging by the dents in the petrol tank its been down the road a bit!
I have fitted the complete uncut wiring look from my TRX, so that was that sorted, need to adapt the ignition barrell wiring from the R1 into the TRX loom.
Also I cant seem to find the 3 pin feed from the alternator, can someone take a photo and show me what it looks like? I have a 3 pin connector in the correct area, but its a completely different fitting. I have used the rectifier from my TRX so the connectors should match up. I have used the entire tdm900 wiring and components on my TRX so I have a lot of spares - handy.
So thats about it so far, one of the curious things on this bike is the guy has drilled the clutch cover and fitted 2 big pipes that come up to the front of the bike. I am thinking positive crankcase ventilation, but why two of them?
I will try and get some regular updates on this.
