Personally I'd start with suspension... new springs (and/or emulators in the forks) to suit your weight either rebuild/respring the rear or find an aftermarket one to suit..depends on budjet.
The brakes works quite fine from std but all the rest isn't worth much if your suspension lets you down.
Even when you change gearing by going down one tooth your only placing more stress on the overworked suspension to start.
The std front spring rate is .7kg/mm and the rear is .9kg/mm so fine for a 70kg rider.
(I weigh 85kg and have .9kg/mm in the front and 1kg/mm on the rear as a bit of a benchmark)
Be aware it may be a quick fix by changing the dogbones but once again you start to play with the suspension and the damping/valving ratios in the shock.
(be aware also an R6 rear shock conversion is still another quick fix but ultimately not designed as the damping,valving ,stroke are not set for a trx)so weigh up the money spent there or just a rebuild of std or money put towards a decent aftermarket unit.
So if you choose to spend a few hundred dollars as just purchasing cans,brakes n lines ..
Personally that could easily finance upgrades to the suspension improving corner speed, braking and handling right from the start.
If you want further improvements after that this will easily work within the tollerence of the suspension you have inplace if upgraded first.
my 10c
cheers Brian
http://racetech.com/ProductSearch/2/Yam ... 50/1996-98
