r6 rear shock
radman
r6 rear shock
hi everyone, i have fitted an r6 rear shock but it feels a bit soft i need to alter the preload can someone please tell me to increase is it the large knurled nut that i have to screw up, thanks.
- fung
Re: r6 rear shock
Hi mate.
Questions :
what year shock is it ?
what weight are you kitted up ?
There is a thread on The forum with settings
Questions :
Re: r6 rear shock
I'm about 85kg suited up and to get the static sag right I'm on 5 (1 being the lowest) .. The R6 is a lighter bike than the TRX by around 14kg so even tho the spring rate on the R6 is for a 86 kg rider the spring is probably a little soft than that on the Trx being a heavier bike .. I'm just chasing the length of a R6 swingarm as these factors all play to the damping and springs. Dogbone length comes into play also.. The R6 shock has a 46mm body which is a few mm larger than the TRX so the R6 shock is a improvement than your tired old TRX shock but ultimately once resprung and revalved to suit you and the TRX the shock will be at its prime.. The R6 shocks are known to squatting and I notice this and its probably exasibated on the TRX when hard on the throttle out of corners taking weight further on the rear end and lightening the front causing an slight under steer out of the corner..
radman
Re: r6 rear shock
sorry for the delay in answering, i dont know what year the shock is but i weigh in at 100 kilos ready to go hope this helps, thank you
- fung
Re: r6 rear shock
It seems that many japanese sports bikes come with suspension made for 75 to 85 kilo riders .
Perhaps visit the racetech site and use their spring rate toolkit to see what you need
- M.V.
Re: r6 rear shock
radman wrote:sorry for the delay in answering, i dont know what year the shock is but i weigh in at 100 kilos ready to go hope this helps, thank you
About the same here, spring is a little on the soft side, I'm running max preload or max -1.
Yes, the big aluminum collar is for preload adjustment.
radman
Re: r6 rear shock
thanks for the advice guys i will try it out today thanks
