simmz
by simmz » Sun Oct 07, 2012 5:34 pm
hi all
this question has probably been asked before but i cant find any the answer
im looking to upgrade the fork springs in my Japanese import and just want to check that they are the same as the european ones as everybody only list from 1996 and mines a 1995
thanx in advance si
by dandywarhol » Sun Oct 07, 2012 9:57 pm
To the best of my knowledge, the euro ones have stiffer springs.
simmz
by simmz » Mon Oct 08, 2012 11:53 am
They certainly are soft
Do you know if they are the same length and diameter ie if a buy springs for a 96 European model will they fit
by trixynut » Mon Oct 08, 2012 1:28 pm
Pretty sure they are softer. Forks are same diameter etc so uk spec '96 onwards springs are ok.
You could mess with oil quantity and thickness but I would just slide in some springs first to see how it feels. Can also do this without taking forks out.
Put up a wanted post for some springs.
I have a standard uk spec pair off a bike that had done 20,000 if u are interested....
Dave
simmz
by simmz » Mon Oct 08, 2012 9:21 pm
Hi Dave
Thanx for info and offer but got a set of progressive hagons sorted but just needed confirm they'd fit
Cheers si
