brake caliper piston removal
Post by dixonj » Sun Aug 26, 2012 8:17 pm
I gave my pal Paul (tzx660) my old yzf 750 front brake calipers with seized pistons and he came up with a very usefull idea to remove them.
Simples :D
cal
Re: brake caliper piston removal
Post by cal » Mon Aug 27, 2012 8:02 pm
:D
I like stuff like that!
Cal
M.V.
Post by M.V. » Tue Aug 28, 2012 12:20 am
Top stuff!
I blew mine out with compressed air, but obviously if they're seized, that won't be an option.
bagmaker
Post by bagmaker » Tue Aug 28, 2012 4:12 am
often you can hook up a grease gun to the bleed port, crimp the hose or seal the hose port and pump them out with grease.
the grease gun will generate a LOT of pressure, be careful.
for multiple seized pistons you put a G clamp on all but one, get it moving and change the G clamp to the now free one, etc, etc.
Usually once they start to move the job is 90% done.
Bit of a cleanup afterwards.
Pirtek or hydraulic hose people have all the fittings needed.
I am always hesitant to use compressed air, its a bit dangerous but hey, if you know its dangerous and take precautions, all power to you.
Try to aim the piston in the general direction of a politician, lawyer or insurance salesperson if possible, to lessen the ongoing increase in patheticnuss or society is taking on.
(old persons rant done now, feeling better, go back to busted Yams)
those who can count
and those who cannot
