Hi all
What is the thread size in the swing arm used for where the paddock stand spools screw into?
I tried screwing in a bolt but it didn't go in very far at all before it bound up. I don't know if the thread is damaged or if the bolt I used was the wrong pitch
Cheers!
Swing Arm threads
- Shaynus
Swing Arm threads
I try to be as good a person as my dogs think I am
- Con Rod
Re: Swing Arm threads
Pretty sure it's an m10, but with a fine pitch, your bolts will be m10 standard pitch. Most high tensil m10 should have a finer thread pitch, and its difficult to find stainless bolts with the fine pitch. Pro bolt have the though.
- Kayla
The thread in the swingarm is M10 x 1.25 and most M10 bolts you can buy from normal DIY places are 1.5mm pitch. This is a good place for stainless stuff-
http://www.a2stainless.co.uk/
pbear62
Hi Shaynus, Definately 10 x 1.25p
Porter Agencies in Malaga can supply a range of bolts in this size. ph: 9444 9944
