need some help asap
biker-nut-1986
need some help asap
Post by biker-nut-1986 » Fri Oct 08, 2010 7:01 pm
heya
i need a favour from some one
im currently modifying my frame
i have lopped off the subframe completly
now to strengthen the frame at the back wher it mounts to the rear engine mount
so could some one give me a measurement at the top of the clutch cover
the measurment from the clutch lever to the begining of the welded in the twin hole mount
id like the measurment from the tube weld to the top of the clutch lever
and the other way to the mount
if you need any more info please pm me and ill trya nd sort a piccie
itll be brilliant if you can
thank you
NWS870R
Re: need some help asap
Post by NWS870R » Sat Oct 09, 2010 2:13 am
Your question is as clear as a doggers window - do you mean the clutch 'arm' :?:
The 'lever' is on the handlebars - post pics if it makes it easier to explain?
biker-nut-1986
Post by biker-nut-1986 » Sat Oct 09, 2010 11:20 am
NWS870R wrote:Your question is as clear as a doggers window - do you mean the clutch 'arm' :?:
yea it is a little vaigue and hard to understnd looking at it again
you are completly correct from the clutch 'arm' to the top of the tube wher it meets the main frame tube ( the longest )
thanks
if you look at the trx of the month you have the crash bobbin not that side from the clutch are to ther other end of the tube if that makes sense
Kayla
Post by Kayla » Sat Oct 09, 2010 1:38 pm
In a 'shutting the stable door after the horse has bolted', or a 'measure twice, cut once' kind of way, would it not have made sense to brace or jig the frame before you cut it? Anyway, if you stick a pic up and explain what you mean I'll go and measure mine for you.
biker-nut-1986
Post by biker-nut-1986 » Sat Oct 09, 2010 2:24 pm
Kayla wrote:In a 'shutting the stable door after the horse has bolted', or a 'measure twice, cut once' kind of way, would it not have made sense to brace or jig the frame before you cut it? Anyway, if you stick a pic up and explain what you mean I'll go and measure mine for you.
yep was all jigged up and measured alot
it wasnt done just willy nilly like most bodgers do i do my stuff properly
its now come out of the jig and checked again and nothing has moved
ill try and do a photo monday
addded 5 minutes after this post
kayla just got what you meant well me and my manager ( who knows his stuff on this subject ) decided it wouldnt need modification in this way because i didnt beleive ther was space ive now realised ther is space so doing the strengthening now but itll be put back in the jig i made so all the bolts wer bolted to keep everything wher it should be
thanks
kayla shall i send it via email cos i dont know how to uupload pictures ?
NWS870R
Post by NWS870R » Sun Oct 10, 2010 3:40 am
I'm even more confused now #-o
If i knew what measurement you wanted i would walk down to my grudge & return post within 5 mins but i can't make out what you need - if you can't upload pics why not describe what you're doing so we can make an educated guess (& reply in chinese :wink: )
Post by Jak » Sun Oct 10, 2010 10:36 am
biker-nut-1986 wrote:i dont know how to uupload pictures ?
Info below from this thread: http://trx850.motomaniac.net/forum/view ... =40&t=2319
Jak wrote:POSTING PICTURES
1) When you type a message scroll down a bit and you should see tabs, one of which says "upload attachment" ... click on that, then click on "browse" and find the pics on your pc and "add" or "attach" it.
2) If you're linking to a photo on another site then open the picture in your browser and right click on it ... select "copy image location" then come into the typing message box here and "paste" ... then highlight the bit its added (make sure you have all of it) and click on the "Img" box above the box here.
3) If you have the picture uploaded (saved) on an online place like http://www.photobucket.com and then copy the [ img] bit and paste it into your post here.
When you've finished typing hit "preview" and you should see it in glorious colour.
IMG OR URL?
IMG means the picture itself will appear
URL means the link to the picture or website will appear
if it doesn't work the same rules apply as per quoting .... make sure there is or [ur l] at the start and [/i mg] or [/ url] at the end (without the spaces obviously)
Also - some of you might find this bit useful .... I've been mending quite a few lately :wink:
Jak wrote:QUOTES DON'T WORK
If you're quoting someone else then try not to delete any of the [ or / or ] marks ..... at the start of the quote it should say
(quote="Jak") but in square brackets .... and at the end it should have .....otherwise it doesn't appear in a box all nice and neat
I usually "mend" any cock-ups I spot
biker-nut-1986
Post by biker-nut-1986 » Sun Oct 10, 2010 11:06 am
NWS870R wrote:I'm even more confused now #-o
lol
right ill do a pic on monday ( tomorrow )#
and mark it on the frame wher i need a measuremtn
and hopefully i wont confuse people anymore :( lol
cheers guys
biker-nut-1986
Post by biker-nut-1986 » Mon Oct 11, 2010 8:26 pm
here should be a piccie
ther are two lines on the frame with a double ended arrow
this is the measurement i need
the line in the middle of the tube section should be wher the clutch arm is on your frame
you guys are brilliant thank you
Kayla
Post by Kayla » Tue Oct 12, 2010 7:25 am
I get 95mm, from the edge of the weld to the centre of the clutch arm pin. I hope that helps!
biker-nut-1986
Post by biker-nut-1986 » Tue Oct 12, 2010 1:05 pm
thats perfect thank you kayla
now to get it all welded up
if i photo sub lugs can people tell me what ther for and if ther vital
if thats ok ill load em up
