Relocating the battery?
Kayla
Post by Kayla » Thu Apr 29, 2010 3:29 pm
I'm considering moving the battery to where the airbox was as I'll be running Ramair filters when I finally get round to nailing the TRX back together. Has anyone tried this? And has anyone got a spare Ramair sock filter for sale?
Re: Relocating the battery?
Post by Mincehead » Thu Apr 29, 2010 3:33 pm
I think overheating of the battery `might` be an issue Kayla.Remember they can get slightly warm as they are being charged too, although saying that Ducati mount their batteries to the side of their engine behind the fairing so you might be ok.
:wink:
Post by trixynut » Thu Apr 29, 2010 3:59 pm
If it was in a suitable cradle/box with some heat shield material around it, it should be ok.
Honk moved his into the tail unit.
Also, you could look at using a physically smaller battery too.
Alternatively, you gould leave the battery at home and get some really really long extension leads.... :D
Post by Mincehead » Thu Apr 29, 2010 4:25 pm
The latest Dynavolt gel types may be a good idea if you`re thinking of going down the smaller battery route Kayla, and as has been said some isulation would be useful too. :wink:
http://www.dynavolt.co.uk/general.aspx
Or LiFeP04 (lithium ion phospate), they are the way forward in battery technology:
http://www.lifebatt.co.uk/index.html
Kayla
Post by Kayla » Thu Apr 29, 2010 4:45 pm
Mincehead wrote:The latest Dynavolt gel types may be a good idea if you`re thinking of going down the smaller battery route Kayla, and as has been said some isulation would be useful too. :wink:
Or LiFeP04 (lithium ion phospate), they are they way forward in battery technology:
Yep, those LiFePO4 batteries were what I was thinking of, with a nice carbon battery box to put it in ;)
Post by Mincehead » Thu Apr 29, 2010 4:53 pm
Am I right in assuming that you`re going to be trying your hand at carbon fibre laying-up Kayla?
Seeing as you`ve mentioned exhaust hangers and now a custom battery box. :wink:
Beau
Post by Beau » Fri Apr 30, 2010 12:38 am
Why do you want to move it?
It will be sitting higher if you put it where the airbox was. Your aim should be to move weight lower, not higher?
Red Rex
Post by Red Rex » Fri Apr 30, 2010 7:54 am
... and Raceparts do heatshield material specifically for wrapping batteries.
Kayla
Post by Kayla » Fri Apr 30, 2010 8:47 am
Beau wrote:Why do you want to move it?
Well, my thinking is that if I'm removing the airbox (which is quite a weight) there's a space there above the engine that is 'wasted' and putting ~2kg (LiFePO battery) above a 70kg lump (rather than 4kg below a 60kg lump ;) ) won't make a huge difference. Just thinking out loud I suppose, and wanting to know if or how people had done it.
Post by Mincehead » Fri Apr 30, 2010 11:33 am
Yes I agree Kayla, centralising mass and all that techy stuff. :wink:
