Shim question.
CH_R1
- Former Member
Shim question.
Just wondering if anyone knows if the shims for the TRX are the same as the ones used in the R1 motor? Thinking of buying a set of shims but only really worth while if they're the same. Thanks.
Re: Shim question.
Standard sizes are: 7.48mm and 9.48mm where yamaha and suzuki uses the bigger one´s. If yama uses these on all bike´s i don´t know but it´s plausible...CH_R1 wrote:Just wondering if anyone knows if the shims for the TRX are the same as the ones used in the R1 motor? Thinking of buying a set of shims but only really worth while if they're the same. Thanks.
- lars
Re: Shim question.
lars wrote:I had one in my wallet, it's 9.48mm for the TRX
What's the exchange rate Euros / TRX shims?
