GCC carbon hugger/chain guard rubbing Pilot Road2 160/60-17
eldavo
Post by eldavo » Tue Dec 15, 2009 3:22 pm
Just letting people know what something strange I encountered.
The new Michelin Pilot Road 2 160/60-17 tyre's left chicken strip was rubbing in the hugger area, looks like the rear chain guard bolt needs a stand-off bracket.
Previous tyre was a Bridgestone BT-020 160/60-17 that seemed slightly narrower than the new Pilot Road 2 160 width.
The GCC hugger looks physically OK and meets up all bolt holes without problem. The only imperfection is a scratched resin on right side from a stick in the gravel fall by previous owner.
In the meantime of making the stand-off bracket, it's going to get a good clean from the lube and grime buildup on swingarm and inside of hugger.
'99 TRX850 (naked), '94 SRV250, '88 SDR200, '05 TW200 (all Yamaha stable)
Silver
Re: GCC carbon hugger/chain guard rubbing Pilot Road2 160/60-17
Post by Silver » Tue Dec 15, 2009 4:25 pm
I had that trouble with the dunlop qualifier and D208. They were both wider than other tyres, they were 160 tyres but had a width of about 170mm which meant they were real close to the hugger.
I tried to find out why they are all different widths but i was unable to get any answers. You would expect a 160 to be 160mm wide but they arent, Some are, Pirellis seem to be correct.
Dave
