This weep has recently started. Pulling plug 2 (RHS) shows the thread is pretty oily.
Eeew.
Any ideas?
I'm pretty sure I see where you're coming from, but my valve cover gasket just seals around the outside perimeter of valve cover - if it had a leak, wouldn't it be apparent by seeing oil seeping on the outside rather than out through the spark plug drain hole? What I meant by the spark plug/coolant gasket part is circled below:Mincehead wrote:Neither the spark plug rubber cover nor the seal on the coolant pipe hold back oil JL,if your coolant stub O ring was allowing coollant past it would show as a drop in coolant level in the radiator or header bottle,you might even see green or blue coolant leaking(depending on the colour of antifreeze you use).
The rubber cover that`s secured on the HT lead and pushes over the plug is simply there to stop water and road grime ingress.If it wasn`t the risk of such grit and crud getting into the combustion chamber would be high whenever you took a spark plug out.
I`m guessing it`s that cam cover gasket.
