Dyno results I recieved a few months ago showed at 7500rpm a speed of 203kph but I was still running standard gearing then????
Can anyone tell me if gearing information is put into the specs with the dyno computer or what else may have caused this result???
The speed readings from the gearing chart seem extremely close to what the speedo reads with both gearings I've ran..
After entering the overracing website I also noticed the over 2 into 1 into 2 system they talk about, the system was designed for a 180degree crank... Wouldnt the exhaust pulse be different to a 270degree crank and the balance pipe be in a different position for optimum performance??
