180 rear tyres
mickjmag
180 rear tyres
Post by mickjmag » Mon Nov 17, 2008 5:06 pm
I've got my self a collection of slightly used supersport and superstock rubber from a mates R6 and I'm wondering how much clearance if any there is between the swingarm and tyre wall, and is there any mods to be done to slot a yzf rim onto the rex?
Cheers, Mick
steve speed
Re: 180 rear tyres
Post by steve speed » Mon Nov 17, 2008 6:07 pm
mines got this mod you need to turn the spacers down ,,use a dished sprocket and flip that over to get the chain to line up, and the clearance on the tyre is about 8mm depending on what tyre you use ,,i have a dunlop , and its one of the best mods ive done :D :D :D mine was done by trixynut
Kayla
Re: 180 rear tyres
Post by Kayla » Mon Nov 17, 2008 6:21 pm
Tee hee, you boys... Bigger is better eh? :wink:
steve speed
Re: 180 rear tyres
Post by steve speed » Mon Nov 17, 2008 6:54 pm
Kayla wrote:Tee hee, you boys... Bigger is better eh? :wink:
well thats what the girls say :ot:
Re: 180 rear tyres
Post by slow codger » Mon Nov 17, 2008 9:29 pm
:twisted: Apparently its also how you use it....................................
.................................Well whats the point of having a wider tyre if you dont use all the rubber??
Re: 180 rear tyres
Post by Jak » Mon Nov 17, 2008 11:59 pm
Reminds me of the avatar I had a while back .....
Re: 180 rear tyres
Post by cobbadiggabuddyblooo » Tue Nov 18, 2008 12:04 am
Nothin better than to say"I need bigger rubbers than std baby".. :lol:
Re: 180 rear tyres
Post by trixynut » Tue Nov 18, 2008 12:16 am
Mick,
Obvious but don't put a 180 on the standard 5 inch rim!
YZF 5.5 inch rear wheel is an easy mod. If you search posts, you'll find one from Brockzilla where I told him what measurements you need to turn the spacers down to, then put TRX bearings in the YZF wheel to accomodate the TRX thinner axle, flip over the sprocket as long as its a dished type one on one side) fit a 16 tooth front sprocket to account for the bigger diameter on the 180 tyre and all is sweet: no irreversible mods and no machining of the wheel. Brake disc lines up too.
And we all know, bigger is better! 8)
Dave
Re: 180 rear tyres
Post by Killerwhale » Tue Nov 18, 2008 8:40 am
Not the clam though.... :lol:
steve speed
Re: 180 rear tyres
Post by steve speed » Tue Nov 18, 2008 1:51 pm
trixynut is right what he says, and the bike feels a lot more planted when leaned over :D
Re: 180 rear tyres
Post by slow codger » Tue Nov 18, 2008 8:59 pm
:? Kept the sprockets as standard no probs on mine, but then I dont have to ride through the city/town on it. You will have to ask Phuk what it came from, but the spacers and bearings from the TRX didnt fit so the spacers had to be made and used the bearings from the bigger wheel.
Re: 180 rear tyres
Post by Quan-Time » Fri Nov 21, 2008 12:39 am
i THINK 170 is the biggest on a stock TRX rim.
180 can be put on a YZF rim, not sure if you need the YZF swinger to suit.
Ive got a 190 on my R1 wheel, and a R1 swinger.
It turns into corners like poop.
180 would be the biggest id go.. possibly even 170 again.
Re: 180 rear tyres
Post by phuk72 » Fri Nov 21, 2008 8:58 am
A yzf wheel with 180 section tyre will fit in a trx swing arm
Re: 180 rear tyres
Post by HansJ » Fri Nov 21, 2008 10:38 am
Although not recommended, I know some ex-TRXers that used to do trackdays on used 180 race-rubbers (Racetec and the likes) on original rims. They were darn fast, beating many in the fastest group with bog standard TRXs. Might not be the best solution, but definitely rideable and not that bad as many would think.
pennypitstop
Re: 180 rear tyres
Post by pennypitstop » Sun Aug 08, 2010 9:04 am
HansJ wrote:Although not recommended, I know some ex-TRXers that used to do trackdays on used 180 race-rubbers (Racetec and the likes) on original rims. They were darn fast, beating many in the fastest group with bog standard TRXs. Might not be the best solution, but definitely rideable and not that bad as many would think.
This is so true. I used to race my trx on a budget and could get shed loads of 180section tyres cheap. squezing 180 tyres on a standars rim gave a slightly taller profile which was better when leaned right over. I have several race wins and trophys from racing on this set up
