FLOAT HEIGHTS
mally
FLOAT HEIGHTS
Post by mally » Sat Aug 23, 2008 11:24 am
Anyone out there got any tips for setting float heights ? I got a new set of carbs off e-bay that flooded when fitted.i,ve been tweeking them for the past three days and it seems to be all or nothing,the haynes book of jokes idea does,nt seem to work. [-o<
any ideas people ?
Re: FLOAT HEIGHTS
Post by slow codger » Sat Aug 23, 2008 11:26 am
:D Try a search, its been on here before.
davesta
Re: FLOAT HEIGHTS
Post by davesta » Sun Aug 24, 2008 1:37 pm
check the factory pro site, it has a bit of info on how to do it, just type factory pro trx or similar into google and you'll find it...
******* Your ego is writing cheques your body can't cash *******
steve speed
Re: FLOAT HEIGHTS
Post by steve speed » Mon Aug 25, 2008 7:29 pm
as above and the height is 14mm make sure you don't compress the float valve spring when you do it :wink: :wink: :wink:
mally
Re: FLOAT HEIGHTS
Post by mally » Sat Sep 06, 2008 8:46 pm
Thanks for the info.
