New post, same-ish problem...
Post by Killerwhale » Tue Jun 24, 2008 6:48 pm
Well, i make another post as it´s went into 2 different problems really...
Ok, so i´ve now checked all the switches and they give signal....TPS was fekked though. Showed all kind of different values so that will be sorted....BUT.
CDI don´t recognize the signal from the neutral switch but i can measure it there beside the standswitch contact...
So what´s left? ....cut out relay?? It´s this wich set´s the logic isn´t it?? So it don´t get the short from neutralswitch..
Whatcha reckon??
Re: New post, same-ish problem...
Post by youngy » Tue Jun 24, 2008 10:30 pm
no. neutral switch is wired directly to the CDI. does NOT go through the lockout relay first but remove the relay and short out the 2 blue/white wires in the plug.
did you say the neutral light has quit? could be a duff diode in the relay.
