rct
by rct » Sat Mar 29, 2008 10:50 am
anyone use one of these???
i have the other front stand that dose not allow you to remove the front wheel, but as i need to take it off to get it powder coated its no good???
i was thinking of modding the shit stand into the under yoke one. (got the tubing and the welder)
just wanted to know if anyone uses one and if they work ok???
honkdawillydahonk
by honkdawillydahonk » Sat Mar 29, 2008 1:35 pm
I've got one similar from Demon Tweeks. Very handy and easy to use.
rct
by rct » Sat Mar 29, 2008 4:14 pm
honkdawillydahonk wrote:I've got one similar from Demon Tweeks. Very handy and easy to use.
now you just showing off with your sig picture!!!
lol
RCT
kookimonsta
by kookimonsta » Sat Mar 29, 2008 8:18 pm
yea i use one too. very stable. you could just use a trolly jack to pivot the front up enough to take the wheel out. i did it this way a few weeks back to get my forks polished. just used an axel stand to keep it on place.
by phuk72 » Sun Mar 30, 2008 6:31 pm
I've got an NWS Up Front - effing marvelous bit of kit.
punica78
by punica78 » Mon Mar 31, 2008 7:19 pm
I'm thinking about buying this one:
This is the website:
http://www.kern-stabi.de
5 May 2006: Zolder
2 September 2006: Folembray
"Fortitudo. Disciplina. Constantia. Patientia. Contemptus Mortis. Amor Gloriae. Amor Victoriae!"
mikeyvet
by mikeyvet » Wed Apr 09, 2008 7:57 am
My stand looks exactly like that red one in the initial post and it's awesome. You do need to use the right size pin though as it goes into the hollow inside the steering stem. The hole in the TRX is 22mm, so you'll need a 21mm pin.
You need to use a rear stand in conjunction with it.
I bought mine from Kaneg in Australia who are a top mob to deal with. (
http://www.kaneg.com.au)
by phuk72 » Wed Apr 09, 2008 9:25 am
mikeyvet wrote:You do need to use the right size pin though as it goes into the hollow inside the steering stem. The hole in the TRX is 22mm, so you'll need a 21mm pin.
which is a PITA if you have more than one bike - which is why I bought the NWS stand as it is universal
by trixynut » Wed Apr 09, 2008 10:07 am
.....ooh, get you!
by phuk72 » Wed Apr 09, 2008 11:31 am
mikeyvet
by mikeyvet » Thu Apr 10, 2008 12:11 am
phuk72 wrote:mikeyvet wrote:You do need to use the right size pin though as it goes into the hollow inside the steering stem. The hole in the TRX is 22mm, so you'll need a 21mm pin.
The pins in this stand are replacable, it takes about ten seconds. It comes standard with 5 smaller pins and bigger pins are available as well so it should fit your MV, your Brough Superior and your moped as well with the appropriate pin.
davesta
by davesta » Fri Apr 11, 2008 7:26 am
I'm guessing if the pin size for the steering head stand is wrong then it won't work? I have a Anderson steering head lifter which currently has a pin much smaller then the steering stem hole. I can't get the bloody thing to work for the life of me! I bought the stand second hand, and this is the first time i've tried to use it. I guess i'll have to find a new 21 mm pin.
******* Your ego is writing cheques your body can't cash *******
mikeyvet
by mikeyvet » Sun Apr 13, 2008 12:08 pm
My Kaneg stand came standard with smaller pins the biggest being 17mm. It worked in that the bike was lifted but the right size pin is a lot more stable and I guess would be less likely to cause damage inside the steering tube from too much back and forth pressure. Well worth getting the right size pin.
davesta
by davesta » Mon Apr 14, 2008 3:57 am
Well the pin that mine has is only about 11 mm, so i guess i shouldnt be suprised that it doesnt wanna work. I've just ordered a new pin from anderson stands so hopefully it'll be all sweet.
Wombat
- Forum Marsupial
by Wombat » Mon Apr 14, 2008 7:19 am
I've got a foldable Anderson stand, but it looks very similar to the one in the first piccy too.
Had it for a few years. Great
