Recommended Brake Rotors? (Aus)
TRiXy
Post by TRiXy » Wed Mar 26, 2008 12:27 pm
hey all,
just a quick question... Anyone able to recommend a source for Front brake rotors in Aus? I've heard that "aussie bike discs" are good, they're prices are the lowest around ($199ea), but my old man used them for his bike (BMW K100) and he said they were crap, advised me to stay well away. the local bike shop is too damned expensive ($300ea) and probably use the same rotors as aussie bike discs.
any advice is greatly appreciated.
Current Rides:
bobtrx
Re: Recommended Brake Rotors? (Aus)
Post by bobtrx » Thu Mar 27, 2008 8:07 am
I use BRAKING discs , I do mainly ride days , where the discs will show if there is a problem . I can't remember the cost
catch ewe later bob
TRiXy
Post by TRiXy » Thu Mar 27, 2008 1:17 pm
ride days as in track days? or (judging by avatar) touring??
thanks for the input
Current Rides:
sherlock
Post by sherlock » Fri Mar 28, 2008 12:42 am
Just shows the versatility of the 'rex......and yes, the old fella meant the track. He actually takes quite a bit of catching :)
elementary my dear.....
Wombat
Forum Marsupial
Post by Wombat » Sat Mar 29, 2008 12:06 pm
Metal Gear are 'sposed to be ok. And they do a set for the TRX.
davesta
Post by davesta » Sat Mar 29, 2008 12:52 pm
You could always try some american bike parts/accessories sites. None of them will have stock specifically for the trx, but the trx front brakes are the same as some other yamaha models. I know the rear rotor is the same as heaps of other yamahas, so maybe someone here can fill us in on what is interchangeable (yzf600?).
******* Your ego is writing cheques your body can't cash *******
Post by phuk72 » Sun Mar 30, 2008 6:35 pm
davesta wrote:You could always try some american bike parts/accessories sites. None of them will have stock specifically for the trx, but the trx front brakes are the same as some other yamaha models. I know the rear rotor is the same as heaps of other yamahas, so maybe someone here can fill us in on what is interchangeable (yzf600?).
Only other Yam that shares the same size front discs with the TRX is the TDM850
Post by youngy » Sun Mar 30, 2008 6:53 pm
I believe the following bikes are the same fitment:
FZ750 89-91
FJ1200 3CV and 3XW
FZ400
FZR400
FZR600
FZR600R
FZS600 Fazer
XJR400
TZR250 3MA1
Post by phuk72 » Sun Mar 30, 2008 7:09 pm
Same spacing and diameter but different discs (FZR600R for example run thinner discs and they are dished slighlty)
Post by youngy » Sun Mar 30, 2008 7:34 pm
FZR600R part number is the same as the TRX. Maybe different years had different discs or sonething.
Post by Quan-Time » Mon Mar 31, 2008 1:09 pm
theres a mob in QLD that you can send your disks to, and they remove the studs and inners, and press on new disks to your spec (wave, bigger diameter, thicker, etc) but i cant remember the name of them for the life of me. If its a common bike (R1 / CBR / GSXR / bandit / hornet / etc) its fairly much a change-over as they carry stock 9 times outta 10.
I dont know how much they cost, but loads of racers use them.. So obviously the stuff they make the disks out of is fairly good. But obviously a premium price. But get em thicker, should last ages.
Failing that, find a place that sells "Galfer" disks. They are wavey, the same as bobtrx, ive heard great stories about their gear. But dont know if they make a TRX specific disk.. Its worth asking.
Personally, i made my own disks, work wonders, and cost me $50 and a carton of booze. But i have the resources to do it. I use a R1 front wheel, so i dont have a TRX stud pattern to use sorry.
TRiXy
Post by TRiXy » Tue Apr 01, 2008 8:55 am
Quan-Time wrote:theres a mob in QLD that you can send your disks to, and they remove the studs and inners, and press on new disks to your spec (wave, bigger diameter, thicker, etc) but i cant remember the name of them for the life of me. If its a common bike (R1 / CBR / GSXR / bandit / hornet / etc) its fairly much a change-over as they carry stock 9 times outta 10.
I had thought about making my own, but honestly don't know what material they use... laser cutting it would be easy enough, but how to treat it? are they quenched? normalised?
thanks for all the suggestions guys, will look into it...
Current Rides:
JL
Post by JL » Tue Apr 01, 2008 8:57 am
I think quan might be talking about this mob:
The chain gang
They do sprockets and rotors. I haven't had any experience with them though...
bobtrx
Post by bobtrx » Tue Apr 01, 2008 9:14 am
I got a chain / sprocket set for CHAIN GANG and I found them to be exellent worth a call as well
catch ewe later bob
TRiXy
Post by TRiXy » Tue Apr 01, 2008 12:18 pm
yeah, i checked out the chain gang, and they're rotors are zinc coated (galv) just the same as the guy at aussie bike dics.. but they're more expensive. my old man warned me to steer clear of the galv rotors since he had problems with them on his bike... but i half get the feeling he didn't follow the bed-in procedure... anyone else have experience with these???
Current Rides:
