6speed gearbox upgrade
- TonyDevil
i've heard tell of a 6speed gearbox upgrade made by overracing
anyone else heard of it or know if they still make them?
just thought i'd ask here before asking stooopid questions on the OR site incase my source was talking bollox
i'm actually interested in this for a TDM as i'm about to rebuild my spare engine, but the TRX will need doing at some point in the future too.......
TDM900 2003 - commuting tool
Z750 hardtail - project
Re: 6speed gearbox upgrade
I think they modified a YZF750 box....but never went serial.TonyDevil wrote:i've heard tell of a 6speed gearbox upgrade made by overracing
Should be doable....but price???
- TonyDevil
all 3 bikes using this engine have plenty of grunt at top end, they just run out of revs
would be nice to bring the revs down a little for higher speed cruising and give the extra range for better top end
also the standard gearing on the TRX means feathering the throttle until approx 30mph when filtering thru town (this doesnt affect the other models of this engine)
there was a TRX on ebay about a year ago that was a TRX engine with a TDM900 conversion, this also used a 6speed box, alledgedly off a YZF750
i didnt have the cash to splash at the time, the 6th gear is the one thing i think the newer 900 engine has over the older 850 and i'd like to sort that out, its really just a pet interest. while i have an engine apart for rebuilding (including output shaft) i though i might do a 6speed conversion
i have 3 bikes that use pretty much the same engine and a spare engine to play around with
.....and because i think it'd be interesting to do
so why not ?
"if it aint broke, take it apart and fix it"
so why not ?
- ss kustoms
The last model TDM has a 6 speed gearbox but I don't know how the ratios compare. Would be interesting to see if it has a higher ratio in 6th than the trx's 5th.
if so it would give it a higher top end with stock sprocket sizes.
If the ratios are lower than the trx so 6th equates to 5th in the trx box then one could fiddle with sprockets to give the same result. i.e lower revs in top gear for a given speed.
I know I keep looking for another gear when riding.
Hope this makes sense.
Steve
Steve
- HolerTogni
Hi Tony!
As far as I have heard, the 6th gear of the YZF 750 SP is the same transmission ratio as our TRiXIe - so it would be no overdrive to reduce the revs ...
Just found it:
YZF 750: 2,57/1,94/1,55/1,36/1,21/1,08 (from http://www.yamaha-yzf750.de/link2.html German site)
TRX 850: 2,57/1,85/1,43/1,17/1,04 (from Haynes)
Really not much of an overdrive ... at least, the second gear is a bit shorter
Rummaging greetings from Munich!
Just found it:
- TonyDevil
- CULater
The TDM 900 gear ratio is:
1: 2.750 2: 1.947 3: 1.545 4: 1.240 5: 1.040 6: 0.923
Smoke Tyres Not Drugs!
http://media.putfile.com/Smoke-Tyres-Not-Drugs-26
- CULater
Pics of my bike ?wicky wrote: Hello any chance you could post some pics of your MKI 900 on here so Tonydevil & I can see them please ???
i say, you need to look at some more topics
http://trx850.motomaniac.net/forum/view ... c&start=30
