float level height
marky19
float level height
hi, can any one confirm that the float level height is 14mm from the carb bowl surface edge to the top of the float, just touching the needle valve
Re: float level height
If you have the carbs fitted the factory spec is 4.6 to 5.6 mm below the mark on the outside of the carb body.
See pg 6.5 of the service manual.
marky19
what i mean is the carbs are on the bench at a angel, carb bowls are off, measuring from the carb edge to the highest point of the float using a float gauge, is the gauge to be set at 14mm.
- HolerTogni
Hi marky19!!
A member of the German forum had posted a quite lengthy text with pictures, how to measure the float hight if adjusted correctly according to the method in the manual.
When held in the correct position, i.e., the floats are just touching the float needle without pushing it, he measured a float hight on the smaller float of 9 mm.
I could post the link to this post here, but you have to register and it's all in German.
Information forwarding greets from Munich!
marky19
hi thanks for your reply, but is there any chance you could send me the link.
many thanks............
- HolerTogni
