Swingarm lateral movement.
bubbaad
Fitting a yzf750 swingarm that was on another TRX and there is lateral movement, about 10mm when it's bolted onto the subframe which it fits into perfectly. Am I missing something obvious here ? Just doesn't seem right. Any help appreciated thanks.
Tealman
Re: Swingarm lateral movement.
Did you remember to put the bearings in
bubbaad
The needle bearings were never taken out. The movement is side to side along the length of the pivot.
- jpe70
Sounds like you are missing end caps on the swing arm. Still, 10 mm is a lot...
andyaber
Seem to remember spacers inside the end caps maybe. Think I looked at exploded diagrams at local bike shop n ordered them. Cheers, Andy.
bubbaad
End caps are on, swingarm fits into the subframe as it should. I must be missing something obvious......
Just a note in case you are looking at the parts manual or online parts finder...
The part number for the swing arm pivot shaft is 3GM-22141-01.
Both the manual and the online parts finder show the rear axle part number 3BN-25381-00 instead.
Although they share the same pivot shaft, the parts list for the YZF swingarm shows two shims (3XV-22127-00, #4 on the diagram) that are not part of the TRX setup, so maybe these are the parts you are looking for.
Diagram here... http://yamahaoemparts.com.au/partFinder ... tid-850445
bubbaad
Cheers guys, it's the spacers/shims. I must have them somewhere........I hope......
- Tarwetijger
A bit late but I do remember the YZF swingarm had spacers fitted were the original TRX one hadn't. They were located under the end caps if I recall correctly.
