I decided to replace the mirrors, as they never were much good for seeing past my elbow anyway.
The indicators were replaced with LED units, which did not need a new indicator relay.
Thr clutch and brake levers were replaced with nice looking blue anodised cnc units, I had to machine up a brass bush for the clutch lever as the 10mm hole was larger than the 6mm bolt.
The footpegs were worn out and were replaced with some nicer units as well.
The oil drein plug will be replaced at the next oil change, with a blue anodised magnetic unit and an aluminium filler cap.
I have also fitted some larger blue frame sliders to the front axle.
All were purchased via Aliexpress.
I will post some photos of the items installed shortly.
All photos hosted on imgbb.com, as Photobucket wanted actual money to provide the service.
