New main jets
Wally
New main jets
Post by Wally » Tue Aug 29, 2017 6:44 am
I order two one size down main jets. What has arrived is a physically smaller jet same thread size Can I still use these??
Thanks
Re: New main jets
Post by dicky » Tue Aug 29, 2017 6:58 am
If it's the same thread and the right ID hole then the smaller head size is the only problem. It does look a lot smaller.
Can you get it to seal against the o-ring? (assuming there is actually an o-ring, there should be)
Wally
Re: New main jets
Post by Wally » Tue Aug 29, 2017 9:44 am
http://www.showandgo.com.au
Go to micuni jets,, the one I've been sent is N102
The ones in my carbs are N100
It's 8 mm base to hold the brass clip that also holds in the other jet.. the n102 hold the clip in also??
Re: New main jets
Post by dandywarhol » Tue Aug 29, 2017 9:59 am
Mikuni sizes are measured by flow rate and most others size by dimension - no comparison
Racer-unk
Re: New main jets
Post by Racer-unk » Tue Aug 29, 2017 10:41 am
I have been told the spray pattern is not the same for the N102, but it is not a train-smash.....also have them in.
I presume you talking about the "starter Jet" which holds the main jet in place? The Square-round rubber seal is under the Main jet which has no size markings.
