Which master cylinder have I got?
Spiky
Post by Spiky » Wed Mar 15, 2017 10:47 am
Is there an easy way of telling which master cylinder I have?
The bike has blue spots and braided lines, but the braking brings a whole new meaning to the word 'wooden'. It stops, but without any feeling whatsoever.
Ideas?
"Keep in mind that the true measure of an individual is how he treats a person who can do him absolutely no good".
Snod Blatter
Re: Which master cylinder have I got?
Post by Snod Blatter » Wed Mar 15, 2017 7:57 pm
The bore size will be written into the casting of the master cylinder somewhere, quite a large font and in a circle. The stock item is 5/8.
Post by dicky » Thu Mar 16, 2017 2:58 am
You should have the 14mm master cylinder that is standard for all Blue/Silver/Gold R6/R1 calipers.
The 5/8 will work, but it will feel a bit wooden.
Hmm...
Spiky
Post by Spiky » Thu Mar 16, 2017 10:51 am
Snod Blatter wrote:The bore size will be written into the casting of the master cylinder somewhere, quite a large font and in a circle. The stock item is 5/8.
Dang - you're right! Good work that man!
Spiky
Post by Spiky » Thu Mar 16, 2017 11:55 pm
dicky wrote: The 5/8 will work, but it will feel a bit wooden.
Indeed.
And therein lies my problem.
Do the 14mm Master cylinders typically come with the reservoir attached as a part of the unit (as oppose to the remote reservoir that I currently have on my TRX)? I'm currently looking at one from a 2005 FZ6.
Post by alextrx850 » Fri Mar 17, 2017 4:16 am
The size of the master cylinder is on the inside ..or next to the handle bar its bolted to.
Post by Mincehead » Fri Mar 17, 2017 8:14 am
An `example` of what you need for your blue, silver or gold, non radial spot calipers:
http://www.ebay.co.uk/itm/YAMAHA-YZFR1- ... SwdzVXkPUH
