My TRX is drawing fuel past the left carb emulsion tube when idling (with the airbox off obviously) and if I cup my hand over the same intake the engine revs rise
Emulsion tube seal
Emulsion tube seal
Can someone remind me if there's an "O" ring to seal the emulsion tube to the body? It's about 15 years since I changed tubes on a TDM and my memory is mush.
The fuel can be seen spraying down the carb between the tube and the body.
- Stu99
Re: Emulsion tube seal
There is an o-ring that seats in the jet block.
- Stu99
Quick pic.
Thanks Stu - it's coming back to me now. I guess the old ring has perished with ethanol/age. I've got an "O" ring kit in the garage - I'll try a repair tomorrow. Thanks again.
Are those Factory Pro tubes?
- Stu99
Yep, thats my spare set with a factory pro kit installed, the ones on my bike have a tovami kit with factorry pro tubes.
Job done - found an O ring in my box of bits and no more leaking. Idling much better. Might have to do the emulsion tubes sometime - at 11,000 miles there's a little bit of ovalling. The previous owner was a canny rider and didn't rev much - the slides rattle back and forth if lugging the engine and that wears the tubes
I was being an erse when the idle speed rose when I partially covered the mouth - I'd forgotten about the vacuum pipe for the fuel tap
