These will be of a slipper skirt design (similar design to the std yamaha trx pistons) .
12:1 compression will still run with no issues on 95/98 Ron fuel and allows you with enough scope to play with slightly higher compression if you choose to alter squish values under 1.25mm (0.048") or use thinner head gaskets.
They will be lighter, and 1.5 points higher compression than the 10.5:1 JE 878 pistons currently the option most have for oversize Pistons for their TRX.
Unlike the JE piston which utilise a full skirt and domed crown, the gains by using the Arias slipper skirt design is not only in the weight savings, but gains in heat and expansion which all sap valuable horsepower from your motor.
Less weight so less heat absorption and expansion so less wear. Also less reciprocating mass so will spin up faster and again less stress on your motor components especially at higher revs compared to the JE pistons.
The overall crown design will also burn more efficiently than the JE pistons so again adding to the gains you will find from the Arias 878.
I am modelling the Arias 878 on the current 12:1 868 pistons I'm running so I've posted the photos of the std Yamaha piston, Ross 868 and the JE 878 piston to give you an idea of what to expect for your money.
I'm offering this first shippment to the forum members before throwing them out to the wolves online.
Send me a PM if interested
THE STD 10.5:1 TRX850 PISTON ON THE LEFT
12:1 868 IN THE CENTRE
AND THE 10.5:1 JE 878 PISTONS ON THE RIGHT
