New Buy
- Wally
- schmiffee
Re: New Buy
I'm so jealous!! You got that for $400??
Jealous as!! Lot's of things that could be a great base for!
- Wally
Re: New Buy
Nice find Wally. I'm sure you'll have some fun with that.
I like the Japanese custom TRX too, very nice.
dicky.
dicky.
- Kevtrx849
- Moderator
Re: New Buy
Good score Wally, a bit of tlc and good to go.
( HENRY FORD )
( HENRY FORD )
- Wally
Re: New Buy
http://youtu.be/QJWzoOc7Y-I
Next job clean carbs
Looking for some spares
Rear caliper wth hose
front fork tubes
0%
front fork tubes
0%
- M.V.
Re: New Buy
If your fork tubes aren't bent, send them in to Rad Hard Chroming for a once over, should cost around $350 IIRC.
- Wally
Re: New Buy
Thanks chaps
- Wally
Re: New Buy
With calliper pistons removed can you clean them up by bead blasting them?
- M.V.
Re: New Buy
You could I guess, you don't want to take too much material off though. I usually hone then with some very fine wet & dry (1200 or more) using brake fluid as the wet.
Edit: You mean the pistons right? Calipers themselves shouldn't be an issue.
- Wally
Re: New Buy
Can these be saved?????
